Won't shift past reverse
Old Feb 25, 2020 | 01:23 PM
MMB's Avatar
MMB
Unhappy Won't shift past reverse
I have an 86 w-250 4X4 93,000 miles. Replaced trans and moved before finished. When I got back to it discovered my helper had somehow not lined up the park pawl correctly and used the trans to transfer case bolts to suck it up together.[I assume] I pulled the pawl and replaced with one from salvage yard. Now truck back in one piece mostly but when tried to move truck went in reverse backed out and won't make the shift to drive, will go to neutral and that's it won't shift past that point. Also when i start the truck it acts like it wants to take off in drive for just a second. Any help greatly appreciated I've had this truck about 6 yrs now and want to take it out. Hate to have to sell.
Old Feb 26, 2020 | 09:49 AM
Sounds like the linkage is not rite... If you disconnect the linkage from the shift lever at the trans... Will every thing work and sweep ok?
BruceB
May 11, 2015 10:58 AM
hellzombiex
Apr 18, 2014 09:13 AM
koondawg_74 roadrunner
Jul 22, 2012 06:51 PM
Vaugh22
Aug 27, 2009 04:33 PM
skimo0104
Dec 30, 2006 09:50 PM
