another 318 problem
Old Mar 6, 2008 | 10:41 PM
Tough without more info. What gear, speed, and engine RPM are we talking? Only from a dead stop? Any speed? Does it do this in neutral, just blipping the throttle?
Does the acellerator pump work?
My first guess might be poor spark
Old Mar 8, 2008 | 08:16 AM
Once again, this sounds like weak spark. What do you have for ignition? (You failed to mention what year, model)
You running points? Chrysler electronic? Aftermarket?
Might be a weak condensor or bad points, if you are running a "points" distributor,
Might be a bad coil
Might be dirty, broken rotor or cap
Might be bad coil wire or even bad plug wires or both
Might have a plug with a problem, like an internal problem that is acting like a disconnect (not a short or foul)
Do you have a multimeter?
hishiad
Mar 1, 2015 11:06 AM
Brother Mopar
Oct 15, 2013 10:06 AM
cyclone2321
Aug 17, 2010 03:18 AM
nicolette
Dec 19, 2007 12:13 PM
J Dog
Apr 24, 2007 12:08 PM
