What project are you working on?
Old 08-09-2010, 04:17 PM
  #31
kowalski's Avatar
I am currently working on a 66 Fury II. Its all original with a poly 318, a/c, and 10" 4 wheel drum brakes with no power assist. My plans for this car are a built 383 with 911 heads. And since its gonna be faster, Ill need to replace the puny drum brakes with some beefy discs up front. It was origanally silver with blue interrior but some one had started pretting it to repaint and stripped all the paint and never primed it. So it has surface rust all over the bodie, nothing serious. I figure itll make one hell of a sleeper. LOL
Old 08-09-2010, 04:46 PM
  #32
A.K.A Bob Dodge
1966sportfury's Avatar
my 66 came with the 318 poly, i put a 440 in it, got rid of the death trap single bail and put power brake master cylinder with a brake booster. stops just fine with the drums, the only thing i had to do was extend the brake pushrod i think about 2"
Old 08-09-2010, 07:51 PM
  #33
Member
MarkyMark12345's Avatar
FINALLY got the '72 Barracuda put back together. Unfortunately, I never could make the time to do all the things I wanted. Just needed to put it all back together to get back into driving condition. Finished the drum-to-disc conversion for the front brakes. It was easier than I was expecting. Not sure how I should adjust the proportioning valve though. I'll be posting a thread for help there. It was easier than I was expecting!
Old 08-09-2010, 08:43 PM
  #34
Furytom's Avatar
Well Im working slowly but surly on my 77 fury. 4 Door
Anyhow its all stripped down to the body and I just recently finished the wire brushing and sanding the outer shell. I cut some of the floor pans out but didnt clean up the rust on the frame rails yet. Started now with cutting the rust holes out and welding new sheet metal in. Got a good deal on a 440 block and got a complete 400 engine with it. Plan is to stroke it all a bit with the source 440 stuff. Well one step at a time.....LOL
Tomi
Old 08-10-2010, 03:17 AM
  #35
Originally Posted by 76NY440_nTX
Working on a 1976 New Yorker Brougham with a 440/727 combination. Pulled the car out of the mud, got as many of the critters out of it that I could, got a second engine and tranny for it (which is currently being torn down) and am hunting down parts. Pics to follow when I get them better organized.
Both of these vehicles sound like sleepers in the making. Great plans guys! Keep us all posted on the progress. Start a build thread if you want as well.
Old 08-10-2010, 03:18 AM
  #36
You will need to drive the car a little and adjust the valve as you go to get it dialed in properly. It's good to hear that you have got the car back together. Post up some pics of the brake conversion.
Old 08-10-2010, 03:19 AM
  #37
Tomi
Tomi,
A lot of project like you are doing are slow, especially when it comes to tearing it apart and find rust spots and repairing them. Just take your time and it will be well worth it in the end.
Old 08-10-2010, 03:23 AM
  #38
I've slowly been getting work done around the house.
1) I've got the walk in closet just about done, just need to clean it up and finish the trim around the window and door.
2) I cleaned out the garage of everything that wasn't mine and got my axles, motor, tranny and t-case sitting in the middle waiting for the chassis to come home.
3) I'll be working on installing some vents for the attic tonight and tomorrow.
I'm hoping to have a good majority of the little projects done before the first full week in September since that is the week I have off from work to finish the front room upstairs. Work is not helping out though. Been putting in a lot of hours, but on the other hand, I am very lucky to have a job, let alone OT.
Old 08-10-2010, 03:14 PM
  #39
scotts74birds's Avatar
Just picked up a lo mile 99 Cirrus LXI with a motor that jumped time and bent valves. Hoping to find a junkyard motor and make a decent commuter.
Old 08-10-2010, 04:31 PM
  #40
Zach8200's Avatar
I would love to be able to work on my Engine but Im flat broke so the car and engine will go another year sitting. about 12 years and counting
Old 08-10-2010, 05:15 PM
  #41
You must be married. News flash!!! Just offered a guy on craigs a gas powered,stick welder/generator that I repaired, [bought $150, repaired [$3.58 rectifier]...ask $600] for another Cirrus! Needs trans, if thats even it. Bad sensors make these trans's act bad. Worst case...$150 for rebuild kit. I Can sell these cars all day for $1800-$2500!
Old 08-10-2010, 06:56 PM
  #42
kowalski's Avatar
Yea that sounds alot easier than what ive been doing. Like scouring the internet for hours at a time looking for a cheap 76-79 cordoba that i could rob all the stuff i need from. Whats the part number on that master cylinder? If nothin else Id like to start drivin it to work so I can Get some much needed bodie work done on my truck. Thanks
Old 08-10-2010, 07:15 PM
  #43
chlngr1970's Avatar
I got two...
...priority I think should be the '72 D100 318/440 swap. Another one going on, is my '68 Dart 2dr post V8 swap. I just upgraded the rear to an 8.25. Was going to do the front end converson this past weekend, but the GF decided it was the perfect time to redo the bedroom So, we have a new bed, she has a new desk, and the kids get a new Xbox 360 Elite
Not too bad, but I don't get much in these deals...I've come to accept that. When I get my new garage, I'll be happy
j
Old 08-10-2010, 07:38 PM
  #44
Member
I left the camera in my brothers car, so I'll definitely post them when I can track him down again. We're having problems with the car overheating, so we're deciding if we want to put in a bigger radiator, get a better fan (the fan is so weak, its the equivalent of spitting on a forest fire to put it out, just not happening), or both.
Old 08-10-2010, 07:48 PM
  #45
chlngr1970's Avatar
My '70 Duster has been sitting for going on 11 years without some serious effort on it Not bragging, I'm just saying don't feel too bad...sometimes life has other priorities...
j
Old 08-11-2010, 05:56 AM
  #46
A.K.A Bob Dodge
id have to go down where the car is parked, i just got one for a 66 300 bolted right on,
Old 08-11-2010, 09:02 AM
  #47
I'll be picking up a set of 1 tons from a Dodge 3500 later this week/weekend for $400 total. These will be fun to move around by myself.
Old 08-11-2010, 09:05 AM
  #48
Commando's Avatar
Have you looked in the Classifieds section, I bought a whole bunch of Cordoba parts from a guy parting out a 78.
Old 08-11-2010, 04:18 PM
  #49
76NY440_nTX's Avatar
Thanks for the tip. I'll do just that when I get more pics and more progress on it. You would think 300+ pics is enough, but I can't help but document everything. Must be that day job that has me like this
Old 09-23-2010, 06:31 PM
  #50
moparmike's Avatar
New to the site, New to mopar. Just made a deal to purchase my first mopar car and have messed up already. Aquired a complete motor and trans for my 74 scamp. only problem, didnt realize it was a 318 poly with pushbutton trans. oh well. Question: can the push button work with column or shifter, or am i stuck with a trans i cant use. Much help needed. The car is very clean with slant 6 working condition unknown. can i use the poly 318/727 for this A car.
Old 09-27-2010, 09:21 PM
  #51
Breeze's Avatar
Im working on my 67 sat i picked up for a grand. It came with all new interior. All it needed was assembled.Now Im swaping the 318 for a 440 and getting it ready for paint
Old 09-28-2010, 03:05 AM
  #52
Thumbs up
Very cool!
Old 09-28-2010, 03:06 AM
  #53
I'm sure that you could custom fabricate something to make that push button work but I would trade/sell it off and get something that will "bolt right in" (per say).
Old 09-28-2010, 05:38 PM
  #54
Still working on getting the Cirrus done. I'm on the re-assembly phase now. Working 12hr shifts, plus 2hr drivetime. Getting ready for the launch of the up-dated Sebring and Avenger. Put the dual headlight relays in the Ram the other day to bypass the weak wiring. Headlights actually look brighter. Rebuilding the front-end on the father-in-laws 03 Taurus, charity job.
Step-daughter finally moving out!
Old 09-28-2010, 11:06 PM
  #55
blue 68 gts's Avatar
Old 01-02-2011, 10:57 AM
  #56
Beerstop's Avatar
custom
Currently getting my van drivable again, pcm? went out
after that going to prolly fix the body and do a interior custom with insulation, paneling and definitely thinking of a linoleom floor on 1/8 plywood (for ease of cleaning) custom bed/bench flat screen, speaker system/ upgrade the stereo., and put real port holes in the back with screens and i would also like to rig it up R.V. style except no toilet.
Old 01-02-2011, 11:50 AM
  #57
Silverick's Avatar
Well, don't hate on me, but:
I have a '70 Firebird Formula 400 4spd/12 bolt project in the garage that I just put a battery charger on. She'll start and I'm going to get her out of the garage to assess whether I am going to make a decent effort to make her a driver or... let her go. This car is powerful and she'll roast both back tires in second gear, until your done but, has some rust issues that I am not sure that I want to deal with.
Old 01-03-2011, 06:21 PM
  #58
chlngr1970's Avatar
Now WHERE is that ban button again...
Good luck with it. I keep seeing a Firebird like car for sale down by my folks place and often think if stopping in to see what the deals is...
Then I come to my senses and keep looking for MOPARS!
LOL
Good luck!
j
Old 01-08-2011, 10:37 AM
  #59
bboogieart's Avatar
Currently I am getting parts together to get my 68 New Port back on the road.
I still need to get brakes done. It is 4 wheel drum, and I am going to keep it that way. I have a stub frame with a disc set-up but that will go in the fury as it will be more of a performer. Also a Harley FLH but that's another.
Attached Thumbnails What project are you working on?-68-new-port.jpg   What project are you working on?-76400.jpg   What project are you working on?-dual-snorkel.jpg   What project are you working on?-built-tranz.jpg   What project are you working on?-flh.jpg
Old 01-08-2011, 11:27 AM
  #60
bboogieart's Avatar
You ain't the lone Ranger. I been doing this motor swap going on 5 years. Could've just swapped them but I wanted a fresh start. Shoulda left the tired 383 in place. When it's done it will be worth the wait. We are still lucky tho'. Some folks don't even have a mopar. Can you imagine that?
Quick Reply: What project are you working on?
