MSD 6AL on Charger 440 engine
Old 11-16-2014, 09:14 AM
shone190's Avatar
Question MSD 6AL on Charger 440 engine
Hi guys,
I was wondering if I buy MSD ignition 6AL and distributor 8546 and connect as they (MSD) suggest, do I need to left Ignition Module and ballast resistor or not?
As I see on MSD connection diagram, I need to connect 6AL on distributor and ignition coil, so what to do with current wires from Ignition module to distributor and ignition coil? I need to leave them or not? What about ballast resistor?
Thanks in advance.
Old 11-16-2014, 09:23 AM
Just disconnect it and tie it up. just in case you ever want to go back to it.
Old 11-16-2014, 09:40 AM
shone190's Avatar
Thanks, so I can remove Ignition Module and resistor, great info
Old 11-16-2014, 10:14 AM
moe7404's Avatar
i bought a MSD box it failed i a few mo. so i stay with the chrysler setup. easy to trouble shoot and fix. the only week spot is the ballast resistor. so just carry two extra in the glove box. they are weakest in cold or hot weather
Old 11-16-2014, 02:22 PM
Yes.... The O.E.M. Module and Resister Dose you no good with the 6AL
Only thing you can use is the Ignition keyed Hot fir the 6AL. All the rest you can just tuck away in some split loom.
One other thing..... Dont forget to get a Blaster Coil to go with all that your installing... Just my 2 cents...
Old 11-16-2014, 11:06 PM
shone190's Avatar
Off course, I didn't mention that (MSD blaster coil) because it is not important for wiring question I asked
Thanks guys.
Old 11-17-2014, 01:24 PM
Ok...... Just didn't want you get short on Juice....lol
69POLARA383
02-09-2014 09:27 AM
jake's rt
02-24-2012 04:58 PM
moparjohnson123456
06-14-2011 01:28 PM
dsmtuned
06-03-2009 07:06 AM
Mixmastermerrill
08-27-2008 03:28 AM
Quick Reply: MSD 6AL on Charger 440 engine
