The differences between 1973 318 and 1972 318
Old 03-24-2018, 08:25 PM
Nathan Jorgenson's Avatar
I am just want to know is the difference between a 1973 318 and a 1972 318. My uncle did a engine swap in the 80s he does not want to talk about it. I now that the engine is a early 70's engine. Is there any physical ways to tell the engine years apart.
Old 03-25-2018, 07:50 AM
Research the casting numbers on the heads and blocks will give you the basics....
Old 03-25-2018, 09:17 AM
Welcome.
Looked up some stuff and found different P/N's for Pistons and Intake Manifold, likely very little difference just a little juggling of compression ratio and EGR/emissions stuff. Both should still have floating piston pins as P/N's show that changed in 1974.
I could say with confidence that they are virtually identical.
Old 03-25-2018, 08:33 PM
Thanks for the help.
jormymex74
09-05-2016 09:04 PM
norcalitwin26
06-05-2014 02:16 PM
Duster360
02-29-2012 05:07 PM
Commando
04-12-2010 09:45 PM
atowncris
11-19-2009 12:48 PM
Quick Reply: The differences between 1973 318 and 1972 318
