1967 Satellite replace front wheel cylinder
Old Jun 25, 2021 | 11:54 AM
sendust's Avatar
Hi guys i am in the process of replacing my two front wheel cylinders, My issue is one of the bolt heads is obstructed and cannot not be accessed by a wrench or a socket, To try and get better access i loosened the four nuts holding the backing plate, no movement, i placed a jack near the wheel to take weight off of the shocks just in case it was binding the bolts, what am i missing? something is holding the plate tightly in position, also any other ideas on how to remove the obstructed wheel cylinder bolt. pete
Old Jun 30, 2021 | 08:46 AM
scot426Mw's Avatar
Did you get it? If not post a pict of the stubborn nut, not my wife , so we can see what you see.
a
Old Jul 16, 2021 | 07:44 AM
sendust's Avatar
Yes i figured it out, i could not get the backplate off, in the end the bolts were seized on and needed some penetrating's oil and vibration.
Old Jul 18, 2021 | 11:33 AM
Nice.... Mopar on !!! Cheers
Mikey123
Jan 27, 2019 08:10 PM
Arbiter343GS
Apr 6, 2012 10:09 PM
69POLARA383
Aug 12, 2011 03:06 PM
murry
Aug 4, 2011 12:51 AM
x24paul
Jan 23, 2010 04:10 AM
