6 Pack question
Old Dec 25, 2010 | 09:04 PM
Slice's Avatar
6 Pack question
Should the outboard Carbs in a 6 pack setup suck air at idle???
Old Dec 26, 2010 | 08:02 AM
I don't know what you mean by "suck air." The outboard carbs DO HAVE idle circuits, the adjustments are plugged but you can dig them out and get to the screws.
Old Dec 26, 2010 | 08:56 AM
on the original design, the outer carbs acted as secondaries and did not work at idle
Old Dec 26, 2010 | 03:08 PM
Sorry that is not true. I OWNED one and there ARE idle circuits in the outer carbs. They were covered by soft (lead) and if you dug in there, you could adjust them.
(By the way, it's why my nomiker is "440roadrunner." There is NO SUCH THING as a "440roadrunner" UNLESS it is a sixpack)
Look at the diagram at the bottom of this page:
http://www.mopar1.us/6barreltips.html
Notice the idle screws (outer carbs) and "plug set" shown
Old Dec 26, 2010 | 08:17 PM
you are right. i was just saying how the original design worked from the factory.
Old Jan 22, 2011 | 09:27 AM
jpickar's Avatar
You shouldn't need to mess with the air adjusting screws at all. A lighter spring in the dash pots will take care of this problem.
John
734406pack
36
Jun 30, 2015 09:53 AM
70plumchallenger
Jul 30, 2013 09:59 PM
vincecil
Dec 12, 2012 06:07 AM
richk2843
Jun 21, 2008 11:29 PM
nixtreez
Apr 4, 2008 04:28 PM
