68 Charger disc brake conversion
Old Aug 23, 2017 | 06:51 PM
Randy340's Avatar
I am in the process of building a 1968 charger. The car has a power disc/drum brake setup on it. I bought a moser dana 60 rear-end with disc brakes. The engine is a 440 block and the brake booster is a dual diaphragm. What master cylinder do I need for this setup?
Old Aug 23, 2017 | 09:23 PM
There is most likely a spring on the rear drum brake side of the Master to hold a few lbs of pressure on the wheel cyl SO you would have to remove the fitting that is inside where the brake line goes into to remove the spring Or send it out for a rebuild or search parts books for a replacement
Old Aug 24, 2017 | 05:23 PM
Randy340's Avatar
Would that be the small rubber and spring behind the residual pressure valve?
Old Aug 25, 2017 | 09:00 AM
Drag Pak's Avatar
Once all that is sorted? It does'nt hurt to put a 2# residual valve inline to the rear brakes to firm up the pedal.
Old Aug 25, 2017 | 05:17 PM
Randy340's Avatar
Thanks for the tip.
chargermom
Oct 28, 2012 04:02 PM
cyah
Jun 16, 2012 08:21 AM
smackhonda
May 19, 2010 03:02 AM
Hollonator
Mar 2, 2010 11:20 AM
BTKBraden
Feb 22, 2007 11:31 AM
