68 Charger disc brake conversion
Old 08-23-2017, 06:51 PM
Randy340's Avatar
I am in the process of building a 1968 charger. The car has a power disc/drum brake setup on it. I bought a moser dana 60 rear-end with disc brakes. The engine is a 440 block and the brake booster is a dual diaphragm. What master cylinder do I need for this setup?
Old 08-23-2017, 09:23 PM
There is most likely a spring on the rear drum brake side of the Master to hold a few lbs of pressure on the wheel cyl SO you would have to remove the fitting that is inside where the brake line goes into to remove the spring Or send it out for a rebuild or search parts books for a replacement
Old 08-24-2017, 05:23 PM
Randy340's Avatar
Would that be the small rubber and spring behind the residual pressure valve?
Old 08-25-2017, 09:00 AM
Drag Pak's Avatar
Once all that is sorted? It does'nt hurt to put a 2# residual valve inline to the rear brakes to firm up the pedal.
Old 08-25-2017, 05:17 PM
Randy340's Avatar
Thanks for the tip.
chargermom
10-28-2012 04:02 PM
cyah
06-16-2012 08:21 AM
smackhonda
05-19-2010 03:02 AM
Hollonator
03-02-2010 11:20 AM
BTKBraden
02-22-2007 11:31 AM
Quick Reply: 68 Charger disc brake conversion
