? about 318 poly
Old Oct 27, 2010 | 01:14 PM
duane66charger's Avatar
Question ? about 318 poly
ive got a 66 dodge charger with a 318 wide block. im wanting too know is the wide block concidered a big block as far as the transmission goes?
Old Oct 27, 2010 | 01:58 PM
blue 68 gts's Avatar
No.
Old Oct 27, 2010 | 11:20 PM
1966sportfury's Avatar
A.K.A Bob Dodge
understand you confusion i hear alot of ppl say they got a big block 318, referring to the poly, but truth is its just a small block, same crank and there are other things that will fit the LA 318,
Old Oct 28, 2010 | 02:22 AM
What are the differences between the 318 A (poly, wide block, etc.) and the 318 LA motors?
Old Oct 28, 2010 | 12:26 PM
rr69half6bbl's Avatar
.Tim, I know the heads ,intake, valve covers, adn rocker /pushrod setup are different. I think the front of the motor is diff. too. the cahin cover and water pump setup/
Old Oct 28, 2010 | 03:34 PM
A.K.A Bob Dodge
cam is different, to match the poly style rockers,
i heard the other day that you can put poly heads on a LA and the other way around, i cant see that to be true? but ill match some heads up when i get back to where everything is,
TallChris
Dec 1, 2010 03:29 PM
66coronetgirlie
Aug 9, 2010 10:41 PM
ferrell450sel
May 6, 2009 10:41 AM
66coronetgirlie
Feb 25, 2008 05:40 AM
zmp
Dec 16, 2007 07:23 AM
