Carb Replacement Questions-manual to elec choke
Old Aug 3, 2009 | 06:27 PM
theomahamoparguy's Avatar
you may need to look for some holley parts on the net [eg:summit.com] for a Mopar linkage adaptor for a holley carb. If your carb was not originally installed on a mopar from the factory, the linkage probably wont work. The linkage adaptor will adapt the Universal type of holley carb to the mopar factory linkage. The best bet for a "kickdown linkage" would be the Lokar mopar kickdown kit. {it is a cable instead of a solid rod}. The trans. kickdown linkage is important because if you dont have this set up correctly, you might hurt the trans over time. As far as the stalling, its hard to say. May need more clues to figure it out.
Old Aug 3, 2009 | 06:29 PM
you could splice into any "key on" power source. {eg: wiper motor hot lead} for the wiring.
Old Aug 4, 2009 | 02:09 PM
i'd go for bigger than 600
twood21
Mar 13, 2014 06:44 PM
HonkyCat
Nov 3, 2012 10:09 AM
cmetzbower
Jun 13, 2011 05:35 PM
c011699
Apr 15, 2010 03:34 AM
67Polara
Mar 1, 2010 10:12 PM
