Engine Serial# Question
Old Jul 4, 2009 | 07:43 PM
ngc414's Avatar
Hi, Im new to the site. Im new to Mopars also. I just picked up a project 68 Charger today. It has what appears to be a 440 in it now, The serial number on the engine is 5T44EHP. are there any websites to check the engine serial # and get more info on the engine?
Old Jul 4, 2009 | 09:33 PM
There should be a couple of numbers on the passenger side of the block. In one of those, it will have the size. If you can get those, we can tell you more about it.
Old Jul 6, 2009 | 05:46 PM
the numbers will give you the info you need
Old Jul 6, 2009 | 05:56 PM
Polaradude's Avatar
If you get the casting #'s off the block we will decode it for ya.
Old Jul 6, 2009 | 06:44 PM
ngc414's Avatar
I cant see any numbers on the passenger side, I might need to wait until I get the engine pulled in a few weeks.
Old Jul 6, 2009 | 06:51 PM
With the suspension, crossmember and exhaust manifolds in the way, it can be hard to see sometimes.
Old Jul 6, 2009 | 08:29 PM
also, dirt and layers of paint make it hard to see
Old Jul 21, 2009 | 03:13 AM
Polaradude's Avatar
Originally Posted by neggy
hey guys! Dont mean to high jack the thread, but I have a very similar question.
I've just pulled a motor out of a garage and the number stamped on the side is 4179930-360-I
Now Im not entirely sure if its an "I" at the end or a one.
What can you tell me?
It's a 360 LA block that was produced between 75 & 93.
Old May 13, 2010 | 10:30 AM
snowdad's Avatar
Junior Member
Dodge engine serial number
Good morning folks. New to the forum here. I just purchased a dodge engine flathead 6 230. The number is L230 *150355* Each asterick is actually a 5 point star. According to research this is supposed to be a 1958 Dodge engine. If so, how much difference is it between this model and the 1942-1945 WW 2 T214 230s? Thanks in advance.
Phillip
Old Jun 4, 2013 | 07:08 PM
Tommie Smith's Avatar
hey, we just bought a dodge motor with casting numbers 3698830.440.9,, can u tell me what that means please
Old Jun 4, 2013 | 08:36 PM
moparted's Avatar
its a 440
Old Jun 4, 2013 | 09:21 PM
info
A 360-1 is first mold poring should be a strong block..
A 440-9 9 parts of the mold have been replaced..
I would sonic check before doing any serious HP
Old Jun 14, 2013 | 06:59 AM
bigmanjb's Avatar
ET = 1975
44 = 440 YOU JUST MISSED THE 0
E = CASK CRANK
HP = High Performance
Nice block other than the cask crank which is not desirable but ok to use in a stock configuration.
Old Feb 4, 2021 | 07:27 PM
Alan Gamelin's Avatar
Question 360-1 information PLEASE :)
Originally Posted by TVLynn
info
I am rebuilding my MOTORHOME and would like more information on CAM (specifications), CYLINDER HEAD CC, INTAKE & EXHAUST VALVE SIZES for the "360-1"
I pulled out my 360 Dodge engine ( Engine code from underneath hood of motorhome - OV9783 360-1 4039783 shown in picture).
Shows the code number for the build, Engine Code, then the casting number of the original motor.
ngc414
Apr 18, 2022 05:41 PM
windsor383
Apr 29, 2014 04:05 PM
dsikkema
Mar 16, 2014 09:32 PM
castillo70
Nov 18, 2012 12:19 PM
56plaza
Sep 9, 2010 06:57 PM
