Intake Manifold
Old Sep 13, 2009 | 04:53 AM
KJoeZ61's Avatar
Intake Manifold
I am thinking about changing my 1966 383 from a 2 bbl to a 4 bbl. I found a great manifold and it does not appear to be warped at all. Anything I should watch out for?
Joe
Old Sep 13, 2009 | 11:37 AM
If you want it to stay original looking, go for a cast intake, otherwise look for alum.
Becareful or striped out threads. Look it over carefully.
Old Sep 13, 2009 | 12:33 PM
KJoeZ61's Avatar
Yeah the one I found is cast and seems fine. No stripped out threads on it. But I understand they can be difficult to seal. Got a Fel-pro pan and gasket set. Just not sure what sealer to use...
Joe
Old Sep 14, 2009 | 03:51 AM
you could always spend the time and money and send the heads, block and intake out and have them all matched. They will plane what they need to and all the surfaces will fit (hopefully) perfect.
Otherwise just go with a really goo gasket set like you have.
Old Sep 14, 2009 | 03:54 AM
KJoeZ61's Avatar
Thanks
Old Sep 14, 2009 | 03:25 PM
scotts74birds's Avatar
Just did this myself. There are two schools of thought here. One is to use permatex gasket adhesive on the head itself and glue a gasket there, leaving all the other surfaces dry for easy removal in the future [they still dont come off easy after a little heat]. Or the recommended way is to use the adhesive to glue the gaskets to both sides of the valley pan after you painted it [you did paint it? Right? No big deal, it just turns into a rusty looking P.O.S.] and taped off the gasket surfaces. Then trim the gasket to fit the intake ports. Kinda messy, and the adhesive doesnt hold that well so the gaskets tend to squirm around. Follow the rest of the directions for the pan end seals. When bolting down, try to get every bolt in first a few threads by hand before snugging any of them. I think some thing in my motor might have been smoothed cause they didnt line up perfectly, ended up with a leak and stripping a hole. Torque to 25ftlbs I believe.
Old Sep 16, 2009 | 01:58 PM
KJoeZ61's Avatar
Well it worked! But it was not fun lining it up, be very careful! Yes I painted everything. I can see how messing up a bolt can happen real easy, two of them gave me a problem to start but worked out ok. According to my 1966 Monaco shop book the tourqe is 50 lbs.
Joe
Polara_68
Jun 13, 2009 11:23 AM
M1 Manifold
May 21, 2009 02:23 PM
67rockabillydart
Feb 10, 2009 07:31 PM
Liu Kang
Jan 25, 2009 05:50 PM
68 Sat
Oct 27, 2008 12:31 PM
