Need Help With Wrecked '68 Satellite
Old Apr 1, 2009 | 03:31 AM
Windcalmer's Avatar
First off, what kind of problem are you having?
Second, are you sure that the body is still square?
Old Apr 1, 2009 | 03:32 AM
I would replace it all with no questions. It take very little force to damage something in these cars like suspension parts.
I would think that any lower control arm from another B-body car of the same year would fit. You should be able to pick them up for cheap on e-bay.
If you are rebuilding just that one side, you might want to rebuild the otherside to make it all the same. Nothing like having a new left side suspension and an old right side.
Old Apr 1, 2009 | 06:24 AM
theomahamoparguy's Avatar
for sure any 66-70 dodge or plym. lca will work. only possible diff might be a sway bar mount. also 70-74 challenger.
Old Apr 1, 2009 | 12:08 PM
Polaradude's Avatar
Exactly. I would be concerned though that it may be out of square.
Old Apr 2, 2009 | 05:21 PM
don't mess with safety
replace everything after a hard hit like that
Old Apr 3, 2009 | 01:45 PM
69Fury3's Avatar
When i totaled my A bod i replaced all of the suspension and steering components on the passenger side only to later find out that the chassis was trashed (had to change the right front tire after 2 months). Definately get that straightened out.
Rumblefish318
Jun 30, 2013 12:56 PM
satellite66
May 21, 2013 07:40 PM
69POLARA383
Jan 11, 2012 07:38 PM
Frank the Tank
Apr 12, 2010 08:08 AM
stanhope55
Aug 25, 2009 05:29 PM
