PCV Valve Connection to Carb
Old Jun 27, 2018 | 05:49 PM
blueshoefly's Avatar
Hey gang,
I'm going to connect a PCV valve to my carb to complete the valve cover set up. It's a 6 pack on a 440. I'm uncertain as to which port I can use to connect the PCV though. I think I can and should use the only port that is visible in this photo at the top of the carb. I can't find any information on it any where else. Can anyone lend some advice? Thanks.
Old Jun 28, 2018 | 01:38 PM
Drag Pak's Avatar
pvc
Center carburetor lower 3/8" nipple
Old Jun 28, 2018 | 03:06 PM
Agreed..
Old Jul 4, 2018 | 06:17 PM
So right now the power brakes' hose is connected to that port as you can see. I've seen a configuration with the PCV connected to this port as you both have indicated. The top port I was thinking about looks like it can be used for the breather hose.
Can I get away with having a breather cap on one valve cover, and a valve cap with a hose attachment going to the carb? OR
Breather on one side, and PCV to carb? What do I do with the power brake hose afterwards?
Old Jul 4, 2018 | 06:32 PM
Also, any photos of your set ups from the valve cover to carb connections?
Old Jul 5, 2018 | 06:22 AM
Archer's Avatar
blue -
PCV and breather should always be on opposite valve covers. Kinda defeats the purpose otherwise.
Kinda easy to figure out out full manifold vac. Find a large bore port, start the engine and feel for suction. If you feel any, odds are you're good to go. An open vac post should cause a rise in rpm. Just remember, the port can be on the carb OR the manifold.
Old Jul 5, 2018 | 01:46 PM
XMANJR
Jun 7, 2019 04:43 AM
bushwood
Apr 29, 2013 04:21 PM
usedknobby
Apr 28, 2013 04:02 PM
1923tbucket
Apr 19, 2011 10:35 PM
64fury
Aug 7, 2010 07:17 AM
