Wiring issues
Old Sep 19, 2009 | 03:04 PM
johnthegoalie's Avatar
thinkin with me dipstick
check out the ron francis wiring kits. you call them and go over all your potions and what not and they build the harness fro you specifically...
Old Sep 19, 2009 | 05:28 PM
theomahamoparguy's Avatar
I cant remember for sure but didn't 74 challenger's have an option for a big block? [maybe a 400].
If worse comes to worse you could always order the wiring for a 74 charger with a 400 big block. I believe the engine compartments were very similar. [as the "E" bodies were actually based off of the "B" bodies]
Probably a 71 challenger with a 383 would be another option. I cant think of too many things that were added to the harness [from 71 to 74]except for maybe some things to do with emissions. The firewall harness plug was the same.
Old Sep 19, 2009 | 06:37 PM
scotts74birds's Avatar
X2, any harness for a 74 E body big block should work. But the wiring guys will tell you for sure. If you have a/c let them know. I think there is an extra wire that fires a dashpot to raise the idle when the a/c is engaged.
Old Sep 19, 2009 | 08:56 PM
http://www.mymopar.com/downloads/1974/74ChallengerA.JPG http://www.mymopar.com/downloads/1974/74ChallengerB.JPG Hope these factory diagrams help you. good to have around. Welcome.
Old Sep 23, 2012 | 04:13 PM
Gorack's Avatar
Would that diagram work for a 70 challenger as well?
Old Sep 29, 2012 | 09:53 AM
Chryco Psycho's Avatar
I believe Year one has optional wiring harnesses available , so you can geta harness for a 70 with electronic ign or you can get a harness for a 73 with a Big block as this is a common swap . the difference yaer to year is the wire positions change as option changed so if you order a 70 Big block harness some of the wires will be in the wrong location in the plug , it is easy to move them . or the other way is to simply extend the wires to the coil , dist & water temp on a small block harness
peterlucas
May 16, 2013 11:08 AM
Cal Lawton
Oct 6, 2009 03:16 PM
Dodge_Coronet1967
Mar 5, 2009 03:12 PM
FatDaddies
Sep 22, 2007 05:40 PM
wtim47
Cuda Specific Discussion
Jun 8, 2007 04:51 PM
