383 rocker arm shaft question "HELP"
Old Mar 24, 2018 | 10:56 AM
cjbennett411's Avatar
Hello I need some assistance in figuring out if the rocker arm shafts from a 1966 ser# 2408516 head will work on a 1960 ser#2206324 head. Seems like the mounting posts on the 516's have a rounded mounting surface where the mounting surface on the 324's is flat. I have attached a picture of the flat mounting surface on the 324's any help would be greatly appreciated.
Thanks
Old Mar 24, 2018 | 11:00 AM
You are correct....
1. Head takes a tube mount... The other uses a stand style rocker asm.
Old Mar 24, 2018 | 11:14 AM
Ok so the tubes I have from the 516's are not compatible correct? And Thank You for the speedy reply!
Robert Weaver
Sep 29, 2014 07:31 PM
DartSwinger
Aug 3, 2010 11:18 AM
scotts74birds
May 13, 2009 04:22 PM
Commando
Jan 7, 2009 07:20 AM
upnorth52
Oct 23, 2008 09:07 PM
