1982 dodge d150 engine swap
An AMC 360 will not bolt up to any mopar tranny. They do not have the same bellhousing bolt pattern. You will need to find another 318 or 360 that is a mopar.
They only way to get an AMC motor to bolt up to a mopar tranny is with an adaptor plus a lot more work than it is worth.
hey 78 dumb question but will the tranny amc from the 360 amc be hard to put in to the truck or how much different is the whole set up on the trans , im just woundering if at all if it would be possible for him to swap the entire motor/trans if he has all of it ... I haven't done much with the amc and was just curious thanks
The only difference in the AMC 727 and Mopar 727 is the bellhousing bolt pattern. The internals are the same. You have to be careful though as some of the wagoneers came with an NP229 t-case (all wheel drive). You can swap it out for a NP208, BUT it wouldn't be worth it in this application. The motor mounts might not line up properly and if they did you would still need to build some motor mounts, tranny mount and crossmember, new driveshafts, do dome wiring, custom built headers..... more than its worth, and I'd personally would rather have a Mopar 360 over an AMC360. The Mopars are easier and cheaper to build.
To me, I would just sell it, try to get your money back, or do something with the AMC 360 and find yourself a Mopar 360 instead. You should be able to find one on craigslist for pretty cheap.
The bellhousing is different, very different. I thought the that they were the same til I saw the two trannies next to one another. It is not worth the work, trust me. You'll want to find a mopar motor rather than machine and adapt the AMC motor to the Mopar tranny.
X2 on the "sell sell sell and buy a mopar 360". I'd find an AMC forum and ask around and see if anyone would be interested in buying it from you. The AMC 360s in teh cars are the same that came in the FSJs.
Andrea Babiak Brady
01-05-2013 07:14 PM
