03 Neon loss of power uphill
Old Nov 8, 2013 | 03:24 PM
Neon2003's Avatar
Car runs OK on level roads. Power loss uphill with max rpm 3k with pedal to floor.
Manual 5-spd with 73k miles. Started 2 weeks ago with two tank refills. No CEL codes. I replaced spark plugs (normal) and air filter. Gave it to the dealer thinking it was clogged cat.
Dealer verified following is good: cat, fuel pressure 58 psi with good flow, timing, injectors, verified back pressure, check for clogged muffler (good), compression good, no vacuum leaks
- replaced O2 sensor - showed rich mixture
- drained gas tank, cleaned fuel lines and injectors
No improvement.
Suggestions welcomed.
Old Nov 8, 2013 | 04:56 PM
Have you checked the timing belt/ verify that it hasn't jumped a tooth
Old Nov 8, 2013 | 06:31 PM
moe7404's Avatar
what did the old plugs look like? does it use more fuel than it should? does the clutch slip?
Old Nov 9, 2013 | 01:34 PM
pro-tech's Avatar
I Agree...Check the timing belt..I have also seen the tube between the throttle body and intake colapse causing it to starve for air...
Old Nov 9, 2013 | 08:54 PM
blue 68 gts's Avatar
Replace the Cam sensor assembly. /thread.
Old Nov 10, 2013 | 05:08 PM
Neon2003's Avatar
Thank for feedback
Dealer verified Timing is correct.
Old plugs showed normal wear.
I suggested to dealer CPS and they reported that it was good.
If dealership service cannot find the root cause then I will change CPS.
Thanks for feedback and all suggestions are welcomed.
Old Nov 10, 2013 | 06:41 PM
If they say all that they've check is good, then your car should be running fine. Obviously something is not right.
I'm still betting on cam sensor and magnet. Common failure. Especially on SRT4 neons.
Old Nov 10, 2013 | 06:42 PM
I just re-read this that it drives fine on level roads.... In that case it's most likely not a cam sensor issue. I'd be leaning more torwards a fuel pump issue. Have them test fuel pressure under load....
Old Nov 11, 2013 | 01:42 PM
CJD AUTOMOTIVE's Avatar
Look at short term adaptive at loss of power. If it starts adding 20+%, it is a fuel delivery problem.
Old Nov 11, 2013 | 04:04 PM
Neon2003's Avatar
Thanks for input
Well dealer put another tech on the issue and he removed the exhaust and it ran fine.
-Clogged CAT.
Mmmm that's what I had them verify in the first place.
Thanks everyone for your feedback.
Old Nov 11, 2013 | 05:03 PM
So it got a new CAT and car runs top knoch?????
Geeeeeeezzzz.... A dam 1/16 drill bit and a pressure gauge and a screw to plug the hole after he takes the reading before the CAT, And he miss read it.....
He's fired...
Old Nov 11, 2013 | 06:44 PM
doesn't the emission equipment have a 100K mile wty ???
Old Nov 14, 2013 | 03:12 PM
pro-tech's Avatar
80,000 mile or 8 years
Old Nov 28, 2013 | 05:15 AM
Fast4door
Jan 11, 2014 08:20 AM
grabbergreendart
Jul 11, 2010 12:00 PM
mystarcollectorcar.com
Dec 4, 2009 07:51 PM
rcknrolfender79
Dec 3, 2009 02:58 PM
67Polara
Aug 5, 2009 06:22 PM
