Jim's36 Overheating problem
Old May 27, 2022 | 05:14 AM
Jim's 36's Avatar
Hello Everyone I'm new hear and need help.Just got a new 36 dodge coupe with a 340 small block.I changed the heads to Edelbrock rpm and the intake to the Edelbrock rpm air gap.Put in a new aluminum radiator new water pump new thermostat.Overheats now after startup.Engine goes up to 250 and the hoses in and out of the radiator are cool.Can't figure it out.Also I thought maybe I was having a problem with maybe air in the cooling system so I purchased the air evacuation system from Summit and used it to put in my antifreeze and it worked well but the problem is still there.
Old May 27, 2022 | 07:18 AM
Wow, Hoses are cool to the touch?
Check it with a Heat Temp Gun and see what it says?
Is the car boiling over?
Could be possible that the Gauge Sender was damaged during the change over?
Old May 27, 2022 | 07:50 AM
if engine is hot and hoses are cool, maybe there's a blockage in radiator or the tstat is garbage?
Old May 31, 2022 | 08:46 PM
FrankieD's Avatar
Pull the T-Stat out and run it and see what happens. I also drill a1/8th hole in the flange in the stat to let the air out. Could also have the wrong head gaskets and a water passage is blocked some Chevys were like that. You can also take the radiator cap off and see is any water is moving.
lotrucker
Oct 6, 2016 08:29 AM
babyboop8668@hotmail.com
Jun 19, 2016 07:50 PM
wizman
Jun 3, 2016 07:28 AM
Onslaught874
May 17, 2013 07:06 PM
Steve Danton
Mar 24, 2009 02:13 AM
