Just bought 67 barricuda needs more power.
JUST BOUGHT CAR HAS 273 WITH A 3 SPEED AND I THINK A 7.25 REAR END. The rear end makes a noise when I let off the gas and also have some vibration. When o get around 55 for just a few seconds. IT FEELS WEAK THINKIN G OF 340 OR 360
Welcome. Without knowing the condition of the car I would build a rear to take the future power you plan to make so you can keep driving while building engine and trans.
I use to get all excited in a situation like this and start tearing it apart to be left with a torn apart car I can't drive and lots of thoughts of what it will be. If you go SB stroker when it's ready it will drop right in quickly and have you driving again.
i found a good rear end site.
http://www.forabodiesonly.com/mopar/...d.php?t=120497
http://www.moserengineering.com/comp...pack-dana.html
https://www.coperacingtrans.com/inde...863bc0dc42502f
http://www.mrlperformance.com/
All the fine ingredient's you need....
You need Help With Installation.... Bring it...I'm only $50.00 Bucks an Hour..
Dont Cause call Us....
Welcome to the forum.... Doing this one step at a time makes a lot of sense... You get to drive it more and that is what our Mopars are about.. Also be sure to check out the Mopar of the Month contest....
I'd fix the vibration first. Think about what you want to do with the car and base your build on that. Write down everything you want for the build and then start gathering parts. Once you have everything, then start the build. Like others said, this will allow you to still enjoy the car now and the build tie will be shorter.
