Just bought 67 barricuda needs more power.
Old Sep 26, 2013 | 06:44 PM
kgraham's Avatar
JUST BOUGHT CAR HAS 273 WITH A 3 SPEED AND I THINK A 7.25 REAR END. The rear end makes a noise when I let off the gas and also have some vibration. When o get around 55 for just a few seconds. IT FEELS WEAK THINKIN G OF 340 OR 360
Old Sep 26, 2013 | 06:50 PM
You need to change the complete drive train...
IF you want big HP get a 408 stroker small block DON'T try to put a BB in it
Old Sep 26, 2013 | 06:59 PM
X2.....
Old Sep 26, 2013 | 07:02 PM
kgraham's Avatar
Thanks
Old Sep 26, 2013 | 07:30 PM
Welcome. Without knowing the condition of the car I would build a rear to take the future power you plan to make so you can keep driving while building engine and trans.
I use to get all excited in a situation like this and start tearing it apart to be left with a torn apart car I can't drive and lots of thoughts of what it will be. If you go SB stroker when it's ready it will drop right in quickly and have you driving again.
Old Sep 26, 2013 | 07:47 PM
kgraham's Avatar
YEAH I THINK I WILL PUT ANOTHER REAR END IN IT. WHAT REAR END SHOULD I PUT IN IT? WILL
A.8.75 work?
Old Sep 26, 2013 | 08:08 PM
moe7404's Avatar
i found a good rear end site.
http://www.forabodiesonly.com/mopar/...d.php?t=120497
Old Sep 26, 2013 | 08:30 PM
http://www.moserengineering.com/comp...pack-dana.html
https://www.coperacingtrans.com/inde...863bc0dc42502f
http://www.mrlperformance.com/
All the fine ingredient's you need....
You need Help With Installation.... Bring it...I'm only $50.00 Bucks an Hour..
Dont Cause call Us....
Old Sep 26, 2013 | 09:18 PM
Silverick's Avatar
The vibration could be as simple as a universal joint...
Old Sep 26, 2013 | 09:27 PM
slade's Avatar
a 8-3/4 will work but it must be an A body rear. i think you going with a simple 340 with alittle head and cam work you will be more than happy were are u located?
Old Sep 27, 2013 | 02:26 AM
kgraham's Avatar
Located in Cleveland Tn. Next to Chattanooga.
Old Sep 27, 2013 | 04:37 AM
Welcome to the forum.... Doing this one step at a time makes a lot of sense... You get to drive it more and that is what our Mopars are about.. Also be sure to check out the Mopar of the Month contest....
Old Sep 27, 2013 | 04:45 AM
I'd fix the vibration first. Think about what you want to do with the car and base your build on that. Write down everything you want for the build and then start gathering parts. Once you have everything, then start the build. Like others said, this will allow you to still enjoy the car now and the build tie will be shorter.
Old Sep 27, 2013 | 05:50 AM
rickyr's Avatar
Old Sep 27, 2013 | 07:33 AM
kgraham's Avatar
GOOD ADVICE. I LOVE DRIVING THAT CAR. Bought it to resell but got attached already. Love it.
Old Sep 27, 2013 | 08:07 AM
WoooHooo... Another Tenn-See-in.... Love the car Dude ...Welcome to the site...
I'm a misplaced TN. boy out here in SO-CAL..... Originally from Memphis
And Man Do I miss Home !!!!!!
Old Sep 27, 2013 | 08:25 AM
70-74? Dart, Duster, Valiant, Demon 8 3/4... Easy to change gears on. You could also use a 8 1/4 more for street duty and an occasional drag strip visit - NO slicks
BadMoose
Dec 19, 2010 10:46 AM
73Badsport
Jun 26, 2009 10:53 AM
chlngr1970
Jun 19, 2009 01:57 AM
cudaneil
May 16, 2009 05:32 PM
mopar nate
Apr 29, 2009 06:54 PM
