New to forum
Old Jan 25, 2022 | 05:35 PM
NewToMopar's Avatar
New to forum
Acquired my sons 2007 dodge ram 1500, 4.7 v8. 4x4 He passed about 3 weeks ago at 18 years old. Truck didn’t have a key so I bought and replaced the lock cylinder. It does fire up briefly but then dies. What is the purpose of the control module receiver that wraps around the ignition and plugs into the ignition switch?
Old Jan 25, 2022 | 06:07 PM
80-HD's Avatar
you will have to have the key programmed to the truck it has a transponder in it. Im also new here today i hope it fixes it but it sounds like the issue.
Old Jan 25, 2022 | 06:12 PM
NewToMopar's Avatar
Well the module was broken, it was damaged in an accident. Do I need to get a new one then have it programmed? What’s the actual purpose of it?
Old Jan 26, 2022 | 04:47 AM
80-HD's Avatar
it's to prevent theft thats the only purpose I know if but I know newer cars need them to run I'm not sure if there is a way to by pass it sorry man wish I could tell you more sorry for such a late reply
Old Jan 27, 2022 | 07:58 AM
No Way around it as far as I know... Need to get a new transponder and key and Have it coded to the truck.. Hope you get it fixed...
Sorry to hear about your son... Our Condolences to you and the family. (Prayers for Y'all's)
Old Jan 27, 2022 | 08:02 AM
NewToMopar's Avatar
so buy the new control module receiver and since I already bought the lock cylinder w/ key. Take them both to a dealer and have it coded? And thank you for the condolences
Old Jan 27, 2022 | 08:12 AM
Yes, Unless you local key shop has the tool to do it?
Old Jan 27, 2022 | 08:42 AM
NewToMopar's Avatar
i apologize in advance for my stupidity I guess I don’t understand why it needs to be coded. It’s a basic key
New ignition that was bought
Control module receiver
Old Jan 27, 2022 | 09:35 AM
The computer in the truck reads the chip in the key, if they don't match, no start...
So the computer needs to be reprogrammed for the new key...
Old Jan 27, 2022 | 10:46 AM
I really probably should not say this... But Ill just throw it out there... What we have done in the past if we didn't want to pay the high price in Multiple chipped keys. (With a known good chip key) you install it under the plastic cover under the ignition switch. That take care of the proximity issue. then you can just use the blank keys with out the chip, because the chipped key is always active. But it dose make for an easy theft if someone breaks into the vehicle and just so happens to find the key. Security kind of goes out the window. If you know what i mean.
Hope this helps you in your decision.. Cheers
Old Jan 27, 2022 | 10:57 AM
NewToMopar's Avatar
so basically I need to get a chipped key? Get a new receiver and have a dealer code it? The original keys are missing, i just installed a new ignition w/ standard keys. And yes I broke the original receiver. Where do I get a chipped key?
Old Jan 28, 2022 | 06:22 AM
Local Key shop if they can code it OR you will need to go to the dealer...
Old Feb 21, 2022 | 04:13 PM
MaxwesllCarlow's Avatar
Hello everyone! There is such an incomprehensible problem: one day the car simply began to twitch at idle, while the rpm itself periodically changed from 900-1600 and when they dropped to 900 it just dangled like a boat along the waves, but this was only at idle! (the check is off) Without thinking twice, we picked up the computer personal classifieds rochester ny, but did not find any errors! What is it?
moparreeves
Apr 5, 2021 07:25 PM
1973dartswingerdms
Jun 15, 2014 09:36 AM
romero2010
Nov 28, 2013 05:17 AM
73Dodge400
Jan 10, 2011 08:25 PM
Zeus77
Jan 26, 2009 02:21 PM
