New Mopar Purchase
Old Apr 9, 2013 | 06:31 PM
inri's Avatar
New Mopar Purchase
Hello all,
I've come to the "Mopar-Side" and purchased my first Mopar; a 1969 Plymouth Roadrunner 496CI.
The reason for this post is to see if there is a member who can help me with my compression ratio dilemma.
The former owner of the car told me that he's pretty sure the CR is 13:1 and he used a fuel additive to ensure there is no detonation.The cars engine was originally a 440 but has been recently stroked to 496. I don't plan on ******* the car at all, but when I decide to give it a bit of gas I don't want to hear any pinging.
What I'd like to find out is what type of octane rating should I put into the gas tank to keep it above and beyond detonation? Or can I retard the engine or something else...?
Other information that might be useful in finding this out:
I live just above sea level (less than 100')
The summers can be hot around 105 degrees on some days but usually are mid-high 90's
The transmission is a built 727 reverse manual valve with a 4500 Art Howe converter
Dana 60 Rear End with 4:10 gears
I plan on driving the car once, maybe twice a month, on a weekend in good weather from city to city (less than 50 miles round trip)
Lastly, there is a 76 Gas station that sells 100 Octane that I will be filling the tank up with. If I fill up with the type of gas will it be a sufficient octane rating? I don't know the CC of the heads or intake/exhaust info or I'd include those figures.
Please let me know if there is anything else that might be needed that I can get you.
Thanks in advance!
Old Apr 9, 2013 | 06:52 PM
110 octane racing gas. Pull the plugs and do a compression test ! May run on 100 Or you can retard the timing some
Old Apr 9, 2013 | 07:20 PM
Welcome aboard to.
Old Apr 9, 2013 | 07:31 PM
Archer's Avatar
inri -
Like TV said. You do have options.
100 Octane may work, try it.
If you get pinging under moderate load, try retarding the timing.
If the timing + 100 oct doesn't do it and the gas gets too expensive (it will), consider a water injection system. Back the the day Edelbrock made one (I still have it too) and these days the hot name is "Snow". It's an old, like WWII old, technology but does work.
Old Apr 10, 2013 | 05:37 AM
rickyr's Avatar
Old Apr 10, 2013 | 05:49 AM
Sometime they put alcohol in the windshield washer bottle and plumbed it into the air cleaner with a holley jet to adjust flow
Check the NOS parts for a spray bar if you want to get fancy
Old Apr 10, 2013 | 03:09 PM
Welcome to the Forum.... Be sure to check out the Mopar of the Month contest....
Old Apr 11, 2013 | 03:25 AM
Old Apr 14, 2013 | 12:30 AM
challenger's Avatar
Welcome to our forums
Old Mar 16, 2014 | 09:01 PM
Watch out for my Buddy (Harry) He lives up in Sac.... HE loves to cruise that town....
Here he was cruising around SO-CAL at Fontana Raceway or (AutoClubRaceway)
Old Mar 18, 2014 | 09:19 PM
moparted's Avatar
too much cr for a street car
Old Mar 19, 2014 | 08:37 AM
Naaaaaaaaaaaa....
Old Mar 19, 2014 | 10:23 AM
pro-tech's Avatar
:welcome2:
Old Mar 19, 2014 | 10:59 AM
Another option ? Depending on what heads you have ? A switch to large chamber Eddelbrock heads may work
Old Mar 19, 2014 | 11:46 AM
If its a true 13.1.0 CR motor... Your going to need a little more than that to run that dog on...
Check the octane at the pump. You will find it is not a true 100....
Your going to need around 113 Octane rating to get around a 107 True Octane rated fuel.
What is needed in the know department is "Was the engine" built to run on Pump Fuel? If the answer to that is NO. Then a higher Octane fuel must be used.
If that is the case... Go with a VP-110 Fuel.
Head over to Sac. Raceway and pick some up if you cant find any.
Old Mar 19, 2014 | 11:50 AM
Originally Posted by pro-te[URL="https://moparforums.com/forums/members/inri-albums-1969-plymouth-roadrunner-picture6115-img-5830.html"
[/URL]ch;117363]:welcome2:
Old Mar 19, 2014 | 02:46 PM
pro-tech's Avatar
It sounds like it is going to cost alot to take a Sunday cruise in this car...That CR is ok for the track but not so good for the street esp.with Ethanol fuel...Premium fuel hear is 92 octane and $4.09 a gallon and that doesnt last long in a car that gets at best 10mpg....Hope it comes down before the season starts...Bill
Old May 29, 2014 | 08:18 PM
INRI,
Well how are thing going..?????? Any progress or are you still penciling it together?
What the update for us here.....
Hope all is well?
Old May 30, 2014 | 06:01 PM
moe7404's Avatar
see there, ask the right people youll get great answers. glad your here. IMHO. a race engine is more likely to detonate at high RPM than low RPM. am i right Bob?
Old May 30, 2014 | 09:18 PM
It will detonate at higher RPM's you just won't hear it...
Old May 31, 2014 | 06:40 AM
inri's Avatar
INRI,
Hope all is well?
Hi Bob,
I'm still taking it apart! LOL I did pick up a 1000lb engine stand recently. So I'm good for any future engine build. Engine cherry - check, engine stand- check.
I sent out the heads to be ported and was called back two days later by the shipping company that there was a little oil residue found in one of the heads when they were packing them. So they asked me to come down and pick it up and get it cleaned. Then I get to drop it back off and have it shipped!! They told me that when I dropped it off that it would be shipped in two days....
I've been selling alot of the old engine parts to help with the rebuild costs. Cast iron pump, pulleys, old distributor, 830 holley carb etc..
I do have a lot of what I would like on paper. BIG CUBES AND LOTS OF POWER
To be serious though, I do have a lot of what I'd like on an excel spreadsheet that includes part, description, cost, and location (website or catalog). What I'm sold on is going with a roller cam and roller lifters, perhaps Jesel. I've read that moving away from the needle type bearing lifters is like a cure for cancer.
Taking more time than I'd like, but that's probably because the weather is getting warm up here and the family would rather we go to the water slides than purchase a carb?! Crazy huh?
Old May 31, 2014 | 06:42 AM
inri's Avatar
Yup. I can't hear anything other than the engine's exhaust in or outside the car. The rebuild will be less than 11:1 and probably closer to 10.5:1.
Old May 31, 2014 | 07:40 AM
Sounds like a great plan coming together. Cant wait to see what you do? Also cant wait to see a vid's and pictures of how it comes out....
Thats one Fine looking ride...
Keep us posted
Old May 31, 2014 | 07:42 PM
  #24
inri's Avatar
Sold the '69 block with crank, pistons, rods, oil pan etc. today. All this $$ will help with the build!
Old Jun 1, 2014 | 07:21 AM
  #25
I'm Smelling a 572.....
Old Jun 2, 2014 | 05:57 PM
  #26
inri's Avatar
LOL! Man that would be sweet! I'd love a nice AA572MW (All Aluminum 572 Max Wedge)
Afraid I'd have to take out a personal loan for one of those...
scottacheson
Jan 2, 2014 09:02 AM
inri
Apr 13, 2013 07:04 PM
lookingatchargers
Oct 8, 2011 03:59 PM
vstone48
Jun 8, 2011 10:25 PM
