Rack & Pinion Steering A body
Old Dec 10, 2012 | 04:31 PM
Dartman60's Avatar
I'm in process of installing R & P on my 65 Dart Convert. The exhaust manifold on the drivers side is going to be in the way of the steering shaft. anyone know of another manifold that would clear the K-frame once the old steering box is removed?
Tom
Old Dec 10, 2012 | 06:02 PM
rickyr's Avatar
sorry i do not have an answer for you
But welcome to the forum
Old Dec 10, 2012 | 06:21 PM
Niether do I but welcome aboard. I have heard of people using a Ford Mustang II rack and pinion on thier mopars. They also convert the end of the steering column to a heim joint and and some square bar stock and swivel joints to move it out of the way.
Old Dec 10, 2012 | 06:56 PM
There's more to it than just bolting in a R & P Or you could end up with an evil handling car..
Maybe a 340 exhaust manifold would work
Old Dec 11, 2012 | 04:12 PM
Dartman60's Avatar
The 340 manifold is the same as what I have. I'm thinking a truck manifold which dumps in the center, but I don't know how or if that will clear the K frame. I think I have the rest of it worked out. Will post pics when I'm done.
Tom
Old Dec 11, 2012 | 05:55 PM
Moving the rack to the front changes the bump steer
Old Dec 12, 2012 | 02:04 AM
Wish I could assist but I know nothing about this upgrade, sorry.
Old Dec 12, 2012 | 07:03 PM
mikerp76's Avatar
also make sure the rack you have is correct to where you are putting it. ie don't put one made to go behind the tires or one made for the rear infront of the tires.
Old Dec 12, 2012 | 08:24 PM
Chryco Psycho's Avatar
Magnum manifold sits tight to the block & flows well , might try that
Old Dec 16, 2012 | 10:20 AM
Dartman60's Avatar
What year and body style would i look for to find one of these magnum manifolds? Would I need to change both so that they match?
Old Dec 16, 2012 | 05:50 PM
Here are a couple to view, and I'm curious if it is rear steer.
http://www.dormanproducts.com/mobile...4-674-271.aspx
http://www.dormanproducts.com/p-28693-674-233.aspx
Old Dec 16, 2012 | 10:12 PM
This is the Magnum one !
Old Dec 20, 2012 | 06:50 PM
Dartman60's Avatar
The unit I'm planning to use is rear steer. It is from a chevy cavalier. It is the same width +/- an inch. It has enough adjustment to make that work. What I like about this unit, is that the tie rods attach at the center of the unit. I think it will be easy enough to mount. I will have to change the drivers side exhaust manifold to clear the steering shaft to the unit. My car is in the paint shop now. I'll post some pics when i get it back and start on this project.
Old Dec 20, 2012 | 07:26 PM
Here is something I used when designing my front end:
http://www.racingaspirations.com/?p=286
Old Dec 20, 2012 | 08:01 PM
93 was the first year for the magnum , look in Dodge trucks , both would be a good idea
Old Dec 22, 2012 | 06:51 PM
Dartman60's Avatar
Thanks. The origonial manifold circles around the power steering box and is going to be right in the way I think. I haven't done a test fit yet. the car is at the paint shop. I hope to have it back in my shop in a few days.
I went by to check on the progress today and took a few pics. It's coming along.
Attached Thumbnails Rack & Pinion Steering A body-dart2-custom-.jpg   Rack & Pinion Steering A body-dart4-custom-.jpg   Rack & Pinion Steering A body-dart5-custom-.jpg
Old Feb 13, 2013 | 04:53 AM
hemidodge1964's Avatar
Rack and Pinion
Can you give an update on how your rack and pinion is coming along.
Regards
RetroRack Global
Mar 24, 2014 07:39 PM
floridamtbiker9
May 5, 2013 08:00 AM
Zoomer59
Feb 13, 2013 06:38 PM
Leem
Oct 29, 2011 07:13 PM
6fury4
Dec 28, 2009 08:30 PM
