What's the proper temp for engine and coolant on hemi?
Old Jul 6, 2018 | 10:19 AM
Bavo33's Avatar
I have a 2011 jeep grand cherokee 5.7L my engine oil temperature was up to 230 is that normal on my coolant it goes up as well to 226 and then the fan kicks in just wanted to know if that's normal on both.
Old Jul 6, 2018 | 07:36 PM
Sounds about rite for the water temp... 210* around these parts... So I would say that is good on your part....
Now the engine oil being 230*… That I'm not sure of... That seams high to me... Now that would be in the ball park for a transmission under a load. That would be a good number.
Just my 2 cents.... Keep us posted.... Good question....
Welcome to the site....
Old Jul 6, 2018 | 07:46 PM
Bavo33's Avatar
Engine oil temp
Thanks.... my transmission oil stay at 180 it's just on the engine oil that worries me
Old Jul 6, 2018 | 07:52 PM
Is that the number that comes up on the message center?
Old Jul 6, 2018 | 08:02 PM
Bavo33's Avatar
Yes I'm just going on what it displays
Old Jul 6, 2018 | 08:12 PM
One of my good sources just got back to me and said..... Oil Temp should run a few degrees hotter than the cooling system....
Go figure, I totally would have got that wrong on my ASE test....lol
Old Jul 6, 2018 | 08:16 PM
Bavo33's Avatar
Lol nice I'm new to hemi usually I take it to the shop and had bad experiences now i try to work on it my self lol thanks alot now I can kind of relax a bit lol I'll be on here more often with questions
Old Jul 11, 2018 | 05:01 AM
ZEN357's Avatar
I think they run too hot. I'm going to put a 180 degree thermostat in my Challenger and replace the computer with a diablo sport and tune the fans accordingly.
Old Jul 11, 2018 | 08:58 AM
Be careful... Keep a close eye on the Cat's, if you cause a failure the cost add up fast... Make sure it's burning everything fuel wise.... Just my 2 cents..
Old Jul 11, 2018 | 11:36 AM
Bavo33's Avatar
Is better to put in a 180 thermostat then the regular 203?
Old Jul 11, 2018 | 08:23 PM
I don't believe so on these later model cars and trucks. It's built into the ECU and PCM and BCM's to look for these corrected temps... I'm under the belief that in order to do something like that correctly you will have to remove a lot of other variable's…. Like Cat system's, remap the fuel system, remap the temp sensors and all the others sensors to boot. Anything thing that will set the MIL light, will need to be readapted with another form of format and or hardware / software...
Then your going to run into pass a smog check if you are needing one of them... Feww
Propar
May 20, 2019 11:39 AM
flashman
Aug 10, 2018 05:20 AM
kcunningham1999
May 4, 2017 05:02 PM
Amos 33
Jan 29, 2012 05:33 PM
haffjones
Aug 2, 2010 05:13 PM
