1993 Dodge ram 5.2L
Old Mar 26, 2022 | 07:59 PM
stillrunnin's Avatar
1993 Dodge ram 5.2L
I have a 1993 Dodge Ram with a 5.2 liter engine. It runs good however when I let off the accelerator all the way the motor dies. It doesn't seem to be as bad in cold weather but in warm weather it will die every time if I don't manually keep the idle speed up a little with the accelerator. It was throwing an egr system failure code so I replaced the egr valve. That didn't seem to help. I have also put a new throttle positioning sensor on it. Does anyone out there have any suggestions? Thank you for any input.
Old Mar 26, 2022 | 09:02 PM
Im thinking idle air sensor and valve, I've had the valve start sticking closed , I tried cleaning it out but ended up replacing it.
Old Mar 27, 2022 | 06:25 AM
1993 Dodge
Can it be checked out some way or do you just replace it with a new one? Either way I will try it since I am stumped. Thank you for the reply.
Old Mar 27, 2022 | 09:13 AM
Well... Im a little late to the party....
I would say pull the hose on the EGR and see if that fixed the issue, even after replacing.
However, Now your going to have to reset the TPS (Throttle Positioning Sensor) With a Scam Tool, like a DBR Scanner.
I also agree with checking the (Idle Speed Motor or IAC Idle Air Control) what ever it has on the truck.
Also, Check for vacuum leaks.... Some of those will blow out the throttle body base plate gasket.. Not to expensive or hard to replace if needed..
Old Mar 27, 2022 | 09:09 PM
I will pull the hose on the EGR and see what that does. I put a new IAC on about a year ago but I will check that out also. Thank you much for the suggestions. I will get back when I find the results.
Old Mar 27, 2022 | 10:00 PM
We appreciate you getting back with the solution to your problem, help’s the next guy.
Old Apr 4, 2022 | 01:04 PM
Hello and thank you for the input. I got back on the idle issue with my 5.2L. I pulled the EGR hose then drove it a couple miles through some stop signs and it idled down and stayed running although it stumbled a little before catching itself and idling smoothly on the last couple. Then it started dying again when I let off the gas. I still have a suspicion it is related to the operating temperature of the motor. As the motor gets warmer the idle seems to fall off. When I turn it back on after dying it idles perfectly so I'm still hunting for the problem. Any more ideas would be greatly appreciated. Thank you much. Stillrunnin
Old Apr 4, 2022 | 01:52 PM
Try removing the air hose in front of the throttle body and spray it down with carb cleaner while moving the throttle open and closed. I had a 95 that required this every once in a while.
Old Apr 5, 2022 | 05:58 AM
Also Check for a faulty Coolant Temp Sensor..
Old Apr 5, 2022 | 05:35 PM
I will do that first thing. Thanks much.
Old Apr 5, 2022 | 05:45 PM
Interesting you mention the coolant temp sensor. The temp gauge never reaches operating temperature. Always runs cool even on hot days although on hot days it gets closer to operating temperature. I have wondered if the previous owner removed the thermostat. Is the operating temperature tied into the idle somehow? This is probably a stupid question but is the temp sensor the same as the sending unit?
Old Apr 8, 2022 | 02:15 PM
You are correct in your assumption.
Yes it needs the correct thermostat or it will not go into closed loop.
The coolant Sensor controls the PCM on the circuit for drivability...
I think on those truck the temp sender is seperate that the Coolant Temp Sensor....
>>>> So you might find that putting in the correct thermostat will fix the problem??????
Old Apr 9, 2022 | 01:15 PM
Terrific! I will take off the thermostat housing and check out the stat. I was really at a loss where to look next. I will get back on here after checking the stat and let you know how it went. Thank you so much.
Old Apr 24, 2022 | 07:54 PM
This is an update. I got called out for work and haven't had a chance to check out the stat on my truck however that is first on the agenda when I get back home. I will then post what the results were. I wanted to let you all know I didn't find the problem after your help and skipped out without informing what I found out. Thanks again.
Old May 22, 2022 | 07:20 AM
Okay I returned from the job site this week and got back on my truck. A previous owner has removed the thermostat for some reason so this kept the motor from reaching operating temperature. I installed a new stat and my idle issue has apparently went away. Thank you people for the input that led me to the problem. This forum is the greatest.
Old May 22, 2022 | 01:10 PM
Good To hear.... Hope you get it running so you can trust driving it all day again.... Cheers
Jeff
Jan 22, 2022 08:19 AM
Aturczyn06
Dec 17, 2021 08:43 PM
84dodge
Feb 20, 2020 02:16 PM
Jentlee2
26
Apr 29, 2016 05:35 PM
stephanie
Jul 25, 2012 04:56 PM
