1967 DODGE DART
Old Mar 2, 2009 | 11:36 AM
72RDRNR's Avatar
Welcome to the forum and glad you decided to do an american build.
If you upgrade to big block it will need a different tranny, not sure about the small block vs 6 cyl. If the funds are there I would look at Hotweelz's recent post -383 BB bored.060 Newly rebuilt . Looked like a good deal to me. Not much expeirence with darts but I would assume that swap has been done often and parts should be readily available? I am sure others will be able to help more.
Old Mar 2, 2009 | 11:43 AM
you can build the slant six to be decently powered
Old Mar 2, 2009 | 12:37 PM
johnthegoalie's Avatar
thinkin with me dipstick
all these slant-6 haters
Old Mar 2, 2009 | 02:11 PM
haha
Old Mar 2, 2009 | 02:26 PM
Not all of us John.
Welcome to the forum fastcarz1990.
67 is right, you can build some decent power with that slant 6. If you go with a V8, you'll want to keep it a SB V8as these cars came with 318s and 340s (some may have had 360s but I am not too sure on that). If you go with a BB V8, you'll have to upgrade the front suspension some to handle the extra weight, not to mention a tranny and rear axle.
If you decide to go with a SB V8, look for either a 318 or 360 as they will be a lot cheaper than a 340 and can be just as much fun. You'll need a 727 SB tranny to back up these motors. While you are at it, you might want to look into swaping the rear axle out for something stronger. There are plenty of aftermarket parts out there for this year car with a SB V8 in it (intakes, headers, cam, carbs, ignition upgrades, heads, etc).
The best advise I can give you is plan out exactly what you want to do and stick with it. It will cost you less in the end, and cost you less headaches as well.
Old Mar 2, 2009 | 02:29 PM
72RDRNR's Avatar
All I can say is there is no substitute for cubic inches!
Old Mar 2, 2009 | 02:30 PM
While is is very true, sometimes money is an issue, especially with the way the economy is right now.
Old Mar 2, 2009 | 02:39 PM
72RDRNR's Avatar
Here are a couple of sb motors in the area:
http://omaha.craigslist.org/pts/1051514420.html
http://desmoines.craigslist.org/pts/1054094126.html
Old Mar 2, 2009 | 06:13 PM
theomahamoparguy's Avatar
Hey im new to the site but I'll throw my two cents in. You can use Schumacher conversion motor mounts to install a small block in your dart.These mounts use the exsisting slant 6 K frame. Find a small block engine/trans at the pick-n-pull yard [try to find one out of a car so the oil pan fits your chassis]. You'll need a bigger radiator probably and exhaust manifolds from a 67-76 A-body [or hedders] , then you might change the rearend to one stronger if you have the 7 1/4 in it now.Up grading the brakes would also be a good idea [lots of ways to go for brake upgrades...cheapest would be "SCAREBIRD" setup in long run]{search net}. ...shorten driveshaft IF you go with the 727 trans and/or use larger rearend. Other issues will probably arise but these are the major ones. Air ride would be cool too but i'm not "hip" on the subject.[I'm sure it could be done. [How much moola do ya plan on spendin and how soon do ya want it]
mrstangblb
Mar 18, 2018 12:27 PM
67rockabillydart
Dec 25, 2012 11:18 PM
gmancase1963
Jun 2, 2011 05:13 PM
kermit1911
Aug 25, 2010 10:14 AM
7ocoronetrt
Jul 8, 2010 09:25 PM
