1972 727 Torque Specs
Hello,
Since I have not gone out and purchased a manual for my 1972 Charger, I do not know the torque specs for the transmission pan bolts. I am going to changing the filter and pan gasket and it occured to me it would be good to know what to torqu the bolts to so I do not over compress the gasket.
Any help?
Thanks, Jake
Any help?
Thanks, Jake
Excellent. Thank you for the information.
One more question. I believe the car originally used Type II tranmission fluid, however, I have heard that people sometimes use Type F because of the improve friction modifiers. I am not sure if this tranmission has a shift kit, I suspect it does, but I am not 100% sure.
So, should I stick with type II or is it safe to use type F?
Thanks, Jake
Thanks, Jake
Well, transmission has been serviced, bolts torked to 12.5. New filter, gasket, and 5 quarts of B&M Trick Shift. Fixed a leak with the speedo housing, adjusted the shift linkage, and inspected the rear seal and ujoints.
Jake
Jake
