1972 727 Torque Specs
Old Aug 6, 2010 | 05:30 PM
jdewoskin's Avatar
Hello,
Since I have not gone out and purchased a manual for my 1972 Charger, I do not know the torque specs for the transmission pan bolts. I am going to changing the filter and pan gasket and it occured to me it would be good to know what to torqu the bolts to so I do not over compress the gasket.
Any help?
Thanks, Jake
Old Aug 6, 2010 | 05:51 PM
blue 68 gts's Avatar
I'd say somewhere around 13ft lbs.
Just get them "snug" and you're good
Old Aug 7, 2010 | 03:44 AM
Polaradude's Avatar
I think its 150 inch pounds for the T-pan. So roughly 12.5 ft-lbs.
Old Aug 7, 2010 | 04:10 AM
DING! DING! DING! We have a winner!
150 in/lbs is correct.
Old Aug 7, 2010 | 06:05 AM
jdewoskin's Avatar
Excellent. Thank you for the information.
One more question. I believe the car originally used Type II tranmission fluid, however, I have heard that people sometimes use Type F because of the improve friction modifiers. I am not sure if this tranmission has a shift kit, I suspect it does, but I am not 100% sure.
So, should I stick with type II or is it safe to use type F?
Thanks, Jake
Old Aug 7, 2010 | 06:12 AM
B&M Trick Shift is what I use, but only because I get a deal on it.
Old Aug 7, 2010 | 06:58 AM
Hey! I was close!
Old Aug 7, 2010 | 09:29 AM
1966sportfury's Avatar
A.K.A Bob Dodge
thighten them till they get loose again!
Old Aug 7, 2010 | 02:14 PM
jdewoskin's Avatar
Well, transmission has been serviced, bolts torked to 12.5. New filter, gasket, and 5 quarts of B&M Trick Shift. Fixed a leak with the speedo housing, adjusted the shift linkage, and inspected the rear seal and ujoints.
Jake
kartman48
Jul 1, 2011 06:49 PM
sweeperking
Feb 28, 2011 03:59 AM
beep1969
Dec 19, 2009 03:16 PM
Mar 18, 2009 06:33 PM
got2mopars
Sep 22, 2007 05:44 PM
