318 to 340
Old Apr 15, 2012 | 05:51 PM
ChrisG's Avatar
318 to 340
Would it be troubling to pricey to change from a 318 to a 340?
i have a 65 coronet 440 and am trying to get as much help as i can.
thank you.
Old Apr 15, 2012 | 07:04 PM
Direct bolt in with the exception of the left motor mount ??? Depends on year of the 340 early were steel crank up to ???? 71 ?? - direct swap later were cast crank balanced converter ?
Old Apr 15, 2012 | 08:20 PM
Could be a tranny or rear end breaker if built properly. Other than that like TvLynn said.
Old Apr 17, 2012 | 07:56 AM
ChrisG's Avatar
Would doing all that be pricey?
I dont have all the funds in the world, but i do have some help with a guy who rebuilt a 1935 ford and a 1973 chevy 10 van.
Hes knows a lot but i would still like some help.
Old Apr 17, 2012 | 12:57 PM
Cost depends on what you have to pay for a 340 motor, Or are you planning to rebuild one ??
Old Apr 17, 2012 | 10:21 PM
MrOldart2U's Avatar
I dunno, is the 318 the Poly or the LA? THAT will make a great difference in the cost of your swap..
Old Apr 19, 2012 | 08:36 AM
ChrisG's Avatar
I dont know if i would buy a 340 already built, or buy one to rebuild. I would just try to get the cheapest one.
I have a friend that might be able to get me a good deal with an engine, but he said dont depend on him.
I have a 318 LA in my car and it is rusted through. I wanted an engine with a little more power without doing a big change with everything.
Old Apr 19, 2012 | 09:04 AM
Chris don't discount 360's which are probably a lot easier to find, and less expensive.
The only real difference between the 340/ 360 is,
You need a 360 specific pan, because the rear seal area is different. You'll need a "car" or front/ center sump pan, as opposed to a van/ pickup rear sump pan.
You'll need to deal with balance between the 318/ 360 converter. The original 360's had weights welded to the front face of the converter. You can buy aftermarket (like B*M) special flex plates that are weighted so you can use 318 (neutral balance) converters.
The engine mount ears are different, but there are brackets available. I actually modified my original 67 273 brackets in my Dart to fit a 360. My 360 came with van brackets, which are very deep. I simply forced the van bracket over the top of the Dart bracket to locate the holes. Drilled one more hole in the pass. side, and welded a simple strap to the other side.
Old Apr 19, 2012 | 12:07 PM
ChrisG's Avatar
Does a 360 use more gas than a 340?
jeffgbaker
Oct 13, 2010 10:56 PM
MartinD
Nov 27, 2009 02:42 PM
O12kona
Sep 1, 2009 08:15 PM
fpereira23
Aug 4, 2009 06:58 PM
greghost
Jan 28, 2008 04:43 PM
