318 to 340
Would doing all that be pricey?
I dont have all the funds in the world, but i do have some help with a guy who rebuilt a 1935 ford and a 1973 chevy 10 van.
Hes knows a lot but i would still like some help.
I dont know if i would buy a 340 already built, or buy one to rebuild. I would just try to get the cheapest one.
I have a friend that might be able to get me a good deal with an engine, but he said dont depend on him.
I have a 318 LA in my car and it is rusted through. I wanted an engine with a little more power without doing a big change with everything.
Chris don't discount 360's which are probably a lot easier to find, and less expensive.
The only real difference between the 340/ 360 is,
You need a 360 specific pan, because the rear seal area is different. You'll need a "car" or front/ center sump pan, as opposed to a van/ pickup rear sump pan.
You'll need to deal with balance between the 318/ 360 converter. The original 360's had weights welded to the front face of the converter. You can buy aftermarket (like B*M) special flex plates that are weighted so you can use 318 (neutral balance) converters.
The engine mount ears are different, but there are brackets available. I actually modified my original 67 273 brackets in my Dart to fit a 360. My 360 came with van brackets, which are very deep. I simply forced the van bracket over the top of the Dart bracket to locate the holes. Drilled one more hole in the pass. side, and welded a simple strap to the other side.
