318 firing problems
Old 07-10-2010 | 02:12 PM
mack.902's Avatar
Junior Member
Unhappy 318 firing problems
my 79 318 seems to idle fine and rev fine but 1/4 to1/2 throtle boggs down the tach drops 50% pleasehelp
Old 07-10-2010 | 07:09 PM
1966sportfury's Avatar
A.K.A Bob Dodge
carburation problem sounds like to me,, floats, a peice of dirt in the carb,
Old 07-10-2010 | 08:32 PM
sweeperking's Avatar
Check distributer mechanical and/or vacuum advance
Old 07-15-2010 | 05:29 AM
mack.902's Avatar
Junior Member
I cleaned carb. checked floats and vac. adv. but not mech adv. yet could pionts do this
Old 07-15-2010 | 09:51 AM
A.K.A Bob Dodge
could if the points are not gaped right, or condenser, has it always been like this? (did you buy like this) or was it running fine then done this, or did you change somthing then it started doing this?,
Old 07-17-2010 | 04:09 PM
mack.902's Avatar
Junior Member
I found the problem a cornet owner told me if the previous owner didn't know what year the distributer was from the points may have an arm that is to long or short making it fire slightlly off the intended post in the cap then vac. adv. pulls it even farther away making it fire on the wrong cylinder or not at all. I pulled the vac. hose off pluged it set the timming by ear no more problem
Old 07-17-2010 | 04:13 PM
mack.902's Avatar
Junior Member
temporary
This will do untill I get in a electronic kit to replace the dis.
xvodysseusvx
06-25-2018 05:38 PM
Wolfpack
05-05-2011 05:05 PM
vintagenc2
08-06-2010 03:13 PM
timmie124
06-28-2010 12:05 AM
KJoeZ61
10-28-2009 01:49 PM
