318 firing problems
Old 07-10-2010, 01:12 PM
Junior Member
mack.902's Avatar
Unhappy 318 firing problems
my 79 318 seems to idle fine and rev fine but 1/4 to1/2 throtle boggs down the tach drops 50% pleasehelp
Old 07-10-2010, 06:09 PM
A.K.A Bob Dodge
1966sportfury's Avatar
carburation problem sounds like to me,, floats, a peice of dirt in the carb,
Old 07-10-2010, 07:32 PM
sweeperking's Avatar
Check distributer mechanical and/or vacuum advance
Old 07-15-2010, 04:29 AM
Junior Member
mack.902's Avatar
I cleaned carb. checked floats and vac. adv. but not mech adv. yet could pionts do this
Old 07-15-2010, 08:51 AM
A.K.A Bob Dodge
could if the points are not gaped right, or condenser, has it always been like this? (did you buy like this) or was it running fine then done this, or did you change somthing then it started doing this?,
Old 07-17-2010, 03:09 PM
Junior Member
mack.902's Avatar
I found the problem a cornet owner told me if the previous owner didn't know what year the distributer was from the points may have an arm that is to long or short making it fire slightlly off the intended post in the cap then vac. adv. pulls it even farther away making it fire on the wrong cylinder or not at all. I pulled the vac. hose off pluged it set the timming by ear no more problem
Old 07-17-2010, 03:13 PM
Junior Member
mack.902's Avatar
temporary
This will do untill I get in a electronic kit to replace the dis.
xvodysseusvx
06-25-2018 04:38 PM
Wolfpack
05-05-2011 04:05 PM
vintagenc2
08-06-2010 02:13 PM
timmie124
06-27-2010 11:05 PM
KJoeZ61
10-28-2009 12:49 PM
Quick Reply: 318 firing problems
