727 ID for Torque Converter
Old Dec 28, 2010 | 01:24 PM
Barfly's Avatar
I have a 727 auto trans, where would I look for identification that would tell me what size the torque converter is, dimensions like 10" or 11" , number of spline teeth etc.....
Thank you
Joe.
Old Dec 28, 2010 | 07:53 PM
1966sportfury's Avatar
A.K.A Bob Dodge
spline count is all the same on the 727, unless its a lock up converter,
Old Dec 28, 2010 | 08:31 PM
Barfly's Avatar
Thanks buddy, 24 tooth spline it is.
Many of the ads I've read talk about 11" or 10" converter and some reference a 10" bolt pattern. Is there a way of telling from outside the trans what I have? Will either or fit regardless of what's in there now?
I would like to have all the parts on hand before tearing into it.
Old Mar 4, 2011 | 06:06 PM
bboogieart's Avatar
What did you find out? I am going to need a torque converter for my 74 727. It's for a big block, and I was wondering if one from a slant six would work? I believe it is the smaller 10" but not sure. It seems to me the smaller converter was used in heavier applications such as trucks and muscle cars. Is this so? Also Greaser you need to match the year to the motor as they were balanced internal or external. As long as the splin is the same it will fit, but balance is an issue.
Old Mar 4, 2011 | 06:28 PM
Barfly's Avatar
I got spun off on another project and have not followed up on this.
I am still interested in a installing a High rpm TC, but know no more about it yet.
Joe.
Old Mar 4, 2011 | 09:31 PM
Cazbah362's Avatar
Convertor Info
Hey guys, going through this issue now Wit a 727: There are couple of different converters - the 19, 24 spline (and 27?). 19 equates to a 1966 and older transmission. The 24 is 1967 and newer transmission. As for the big/small block issue, from what I understand is some or all? SB's have five or more bolt pattern to the converter with a different size flex plate. I'm not a small block guy, so would not know. I am having an issue with a 1966 727. Was not aware there where non-push button 727's out there with 19 splines - seems I am lucky and have one? Anyways do search on 19 vs 24 spline 727's. MoparMag has a great article on these issues along with lock up vs non-lockups, Hope this helps
Old Mar 13, 2011 | 07:19 AM
bboogieart's Avatar
Cazbah362
Thanx for the info. I am pretty sure the bolt pattern on the flex plates are the same on the converter side. I have flex plates for all engine sizes. I was wondering about "application" more than fit, with the /6 converter being up to the big block. I think it is a smaller diamiter unit wich seems to be the way the heavy duty units are. Was just wondering if I can use what I have or if I need a specific big block converter. Don't need high stall but the car is kinda heavy (68 Chrysler New Port 4 door) and thought heavy duty would be best.
bboogie
Old Mar 13, 2011 | 10:55 AM
Cazbah362's Avatar
Flex Plate
bb -
As for the flex plate, I am not sure? One place I have found a lot of help is Pat Blais from Ebay (tflitepatty@verizon.net) He has a store in Washington State and has been a GREAT help. Just off the cuff, I have a 24 spline 11" converter without a flex plate (four bolt) if you would like it. Pay shipping or come by and grab it - Shipping is from Reno area and its HEAVY. It is for an internally balanced motor - IM me if you are interested. Good luck
Old Mar 18, 2011 | 06:18 PM
scotts74birds's Avatar
Never did a Mopar TC, but are some of them weighted for externally balanced motors? Just something to check before you end up with a horrible vibration.
Old Mar 20, 2011 | 03:30 PM
bboogieart's Avatar
Yes indeed balance was on the t.c. as well as the balancer, so an internal balance will not have weights but the external balance will. Not sure when the change took place and with engines and trannies being something folks often changed, you need to check each specific application.
Still no input on the /6 converter working with a mild 400?
Old Mar 21, 2011 | 03:25 PM
Forged crank is a dead give away...if it is an original forged crank motor it will always be an internal balance motor...cast crank 99% of the time external balance...go to Transmission Specialties and get a 9 1/2 convertor...I was told my Rick with A&A that Mopar never made a 10" convertor they were always 11" convertors...the aftermarket 10" ones are from Fords and Chevys
http://transmission-specialties.com/
74cuda
Cuda Specific Discussion
Sep 8, 2017 04:08 PM
67Polara
Jul 28, 2012 01:49 PM
Nomadci
Aug 23, 2010 02:50 AM
smackhonda
May 26, 2010 07:17 PM
68 gtx
Oct 16, 2009 03:43 PM
