Cluster-schmucked!
Old Mar 6, 2020 | 04:58 PM
  #61
74MAX360's Avatar
Hey guys.... how stupid would it be to put the parking brake on -chock the wheels good -and use a jack to apply pressure to a breaker bar to remove the pinion nut?
Will that damage anything? I would imagine the engine puts out more torque than that through the drive shaft -but not sure -I'm trying to avoid having to buy an impact and finding another way to keep the pinion from turning -and definitely don't want to wail on the breaker with a hammer.
Old Mar 7, 2020 | 09:38 AM
  #62
I used my huge buddy's foot and basically the same methods otherwise. It's fine, those are tough sumguns.
Old Mar 7, 2020 | 05:04 PM
  #63
74MAX360's Avatar
Welllll -I'm kind of a loner, so I'll have to chock 'em
Old Mar 7, 2020 | 05:23 PM
  #64
lol! no i mean we chocked em and we used his foot and a big *** bar with a socket on it to break the nut free.
Old Mar 7, 2020 | 06:23 PM
  #65
74MAX360's Avatar
I was thinking your buddy must have been a good sport about it when you asked him
Old Mar 29, 2020 | 02:33 PM
  #66
74MAX360's Avatar
Hey -I got another question -this time about green bearings.
I am confident I can get the old bearings off without messing up the axle, but I don't have access to a press to press on the new bearings.
A guy on the internet used a pipe and fitting -smacked the heck out of it with a hammer instead of using a press.
My question is..... how much pressure do they require -and can I use PVC instead of metal? 2 1/2" PVC has just the right I.D. to fit over the axle and contact the bearing, etc., correctly.
If I stand the axle on some wood -and smack that PVC like it done me dirty -do you think that might work?
If I use metal and a hammer, I am almost guaranteed to scrape up the axle somehow.
Old Apr 3, 2020 | 02:50 PM
  #67
74MAX360's Avatar
After replacing the pinion seal, there are some funky sounds from the rear end. I'm pretty sure it's the wheel bearings, though. It wasn't immediate. I adjusted them to spec (had too much play) before I started driving it -prolly squeezed out whatever dry grease there was left between things and made them angry.
Gonna have to try the PVC idea. I was outside smacking some down on the cement and it didn't break, so I'll be mashing the bearings down butter-churn style with the axle standing on wood.
Good ol' redneck engineering.
I'm not actually sure if I have a sure-grip rear end -better check -maybe need some friction modifier -the gear oil bottle said it wasn't necessary, but this van isn't letting me get away with anything.
I'm setting money aside for a new punkin' just in case. (Stimulus check=$1200 -amazing how a $1200 Mopar part pops into an enthusiast's head -I still have four rolls of toilet paper and I can make it last)
(Also got a remanufactured carb)
Old Jun 27, 2020 | 10:34 AM
  #68
74MAX360's Avatar
Update...
Been road tripping with it. Not much get up and go
off the line -still needs some adjustments -but flies like the wind on the highway -lots of acceleration for passing. Was smooth as butta until I threw a couple stick- on wheel weights -now just a bit noticeable -I can tell where they went, so will have to get some -and spares. I originally wanted no windows, but I love having so many now. Pups love it, too -as well as the fact that I turned the passenger seat around and laid it back.
Old Jun 27, 2020 | 12:40 PM
  #69
Awesome... Glad to see your out getting a little open air !!!! Happy to hear the Pups love it also !!!
Old Jun 28, 2020 | 11:55 AM
  #70
hey, soooooooooo cool!
Timbo
Dec 30, 2018 02:16 PM
70newport
Jun 21, 2014 07:49 PM
Leem
May 6, 2012 11:07 AM
1972GoldDuster
Jul 9, 2010 05:20 PM
68lover
May 21, 2010 08:42 AM
