distributor problems 318
Old Jan 20, 2008 | 10:00 AM
You simple do not have the correct distributor
Here's the list from Accel:
http://www.accel-ignition.com/Produc...minselection=2
According to this ALL small block distributors are the same ---" except Dodge "Magnum" Series 5.2L/5.9L and AMC/Jeep engines (Except Lean Burn)" ---and the "non" LA 318's which means the "early" engines
I'm not familiar with the 5.2/5.9L engines, so I cannot address that
It APPEARS--and I'm not familiar with these--that the SB LA distributor will NOT fit the "early" 318's known as "poly" or "polyspherical."
Also, you may have gotten one out of a 383, I don't remember the shaft length.
Big block engine distributors rotate CCW, OPPOSITE than yours which is CW. Look at the vacuum advance and see if it points the same direction on both units. Or, "spring" the rotor against the advance spring. You can rotate the rotor in the same direction as the distributor turns. That is, if you remove the cap on a SB, and try to turn the rotor, it will turn--against the spring-- CW
Old Oct 17, 2008 | 04:46 PM
Thumbs down
why is there so much spamming going on now?
Old Oct 17, 2008 | 05:07 PM
challenger's Avatar
Angry
i think they think that the admin : are out they can do anything they want at least i have not seen any for awhile even 1bm
Old Oct 19, 2008 | 08:41 AM
anyone know where the server is located?
Old Oct 19, 2008 | 09:22 AM
challenger's Avatar
cant say thet i do 78 but we need to get some one going on this as they are hitting all the old threads and thats not good i just wish 1BM would get on here or some one else and let us know what they are doing about it.. this crap they are putting on here will hurt the forums as the younger gen, will read it and not want to come on here ( is there anyone who might know who we can contact for this garbage
Old Nov 9, 2012 | 04:45 PM
jimmyb's Avatar
is there a shaft extension
Old Nov 17, 2012 | 06:37 PM
moe7404's Avatar
take look at jimsautoparts. i think this is what you need. p3690426. but ask about rotation. small blocks turn clockwise. i am not sure about length. and buy two extra ballasts, put them in the glove box. the first time it doesnt start, just swap out the ballast under the hood.
Old Nov 23, 2012 | 06:57 AM
Gorts 5th's Avatar
Question
what do you mean spam? what have you noticed?
xvodysseusvx
Jun 25, 2018 04:38 PM
jimmyb
Nov 11, 2012 07:22 AM
vintagenc2
Aug 6, 2010 02:13 PM
valleyofthesuns
Sep 24, 2008 09:56 AM
JUS
Apr 16, 2008 03:55 AM
