Engine Advice
Old Jan 24, 2009 | 02:08 PM
deadkelly's Avatar
na mate you will find it costs more to build your own engine .
if you do i like low deck big blocks 383's are cheap and are every where .
forged cranks std . the good thing about big block a are they are so strong & last for ever . & there not that much bigger or heavier .
look at muscle motors complete short blocks & crate engines can't go wrong .
Old Jan 24, 2009 | 03:09 PM
First off, your going to have to find yourself a car. After that, figure out if it really need to have the motor rebuilt or not. A lot of the time you can do simple add-ons and not have to worry abou the block itself (intake, carb, headers, heads, ignition, etc). You would be suprised how much you can get done in a day.
If you have not had any experience or taken classes on rebuilding motors, I would save it for when you have the time, money and someone you trust that can do it with you.
Depending on what you do get for a vehicle and if the motor needs work, it does not always mean that the tranny needs work as well. I have seen plenty of vehicles that needed the bottom end rebuilt of the block and the tranny was just fine.
Like I said, Find a car that you love and then hit us up about it and we will try to do our best to guide you in the right path.
Old Jan 24, 2009 | 03:35 PM
Crazy4Carz.Com's Avatar
X2
Old Jan 24, 2009 | 08:11 PM
Daytona45's Avatar
Junior Member
Question HELP
PLEASEEEEE CAN ANYONE TELL ME WHAT THE BEST THING TO DO WITH MY 1991 DODGE DAYTONA 6G72 AS FAR AS ENGINE SWAPPING GOES???? IM STUMPED AND I HAVE NO EXPERIENCE SWAPPING ENGINES
Old Jan 25, 2009 | 07:13 AM
challenger's Avatar
WOW Well said 3x on that
Old Feb 2, 2009 | 02:06 AM
deadkelly's Avatar
Originally Posted by 1973 duster
hi i need some advise i own a 1973 duster i have a 440 that the numbers on block say 440-3 what is the 3 and it was made 4/1/75 can anyone tell me what horse and torque it has and cheap ways to get horse power and torque i am a father of 3 and one on the way the wife is all for the build icurrently have a mini tub 6 point roll cage dana 44 rear end 31 16.50.15 in street slicks i want to domost of my own work and just need some advice on what to do to get most POWER FOR CHEAP
750 carb , dual plane manifold & 1 in carb spacer , windage tray , msd blaster coil / elctronic ignition , 2200 - 2500 stall converter , extractors . no air cleaner & open headers @ the track . good tune up . mopar muscle .com has some good cyl head tips .
some other free things make your own cold air ducting , use ice / dry ice can incorperated in the duct design so air flows over the cold surfaces .
make a fuel cooler or just tape or strap ice / dry ice around your stock steel fuel line .
block off your exhaust cross over port , you can buy a gasket for this or braze a block off plate .
use morleys or lucus upper cyl lube with you fuel ect to try & clean your heads , even take your extractors / exhaust manifold off clean in side them & while there off clean your exhaust ports best you can .
mate just some free or cheap things to do . one thing may not do much but do em all or a few things & you could knock off 1-2 seconds off your time . you have a light car & big motor .
Rumblefish318
Jun 26, 2013 05:24 PM
tjlamb1987
Oct 12, 2012 07:24 PM
Nightmare
Aug 15, 2012 05:54 PM
TheGuitarsonist
Jul 30, 2012 02:34 AM
ProEmaster
Jun 6, 2007 11:31 AM
