front drum brakes help
Old 09-24-2010 | 08:24 PM
Ted Dugger's Avatar
Question front drum brakes help
Hi All,
I own a 1972 Plymouth Scamp and I had someone redo the front brakes for me and Im thinking he didnt do it riht,does the long shoe goe toward the front or rear of the car.Does anybody have a good pic so I can compare? The problem Im having is its sticking after I drive just a mile or two...any suggestions?
Thanks for any input
Old 09-24-2010 | 11:27 PM
1966sportfury's Avatar
A.K.A Bob Dodge
no pic but the longer pad goes in the front,
Old 09-25-2010 | 06:14 AM
Ted Dugger's Avatar
Ok thanks this will help alot.
Old 09-25-2010 | 07:40 PM
fivepoint's Avatar
I don't think I have ever repaired brakes on a '72 scamp but, I always put the short shoe towards the front on other vehicles. Most drum brakes are servo style systems. When the front lining contacts the rotating drum it will tend to rotate slightly with the drum and force the the longer rear lining to bind tight to the drum. Check a service manual to be sure though.
Old 12-22-2010 | 09:23 AM
MrOldart2U's Avatar
Thats the way I've always done them also.. Long shoe on the rear, but I am not a cert. mech... just a guy with a shade tree....
Old 12-23-2010 | 10:04 PM
Short shoe is primary and goes to the front. Interestingly, my '70 shop manual clearly shoes this pictorially, and never mentions how to ID the primary and secondary. Here's a picture of the right front, clearly showing the primary (front) shoe to be shorter One of my old Motor's manuals also confirms this pictorially. Interesting that no one seems to mention this in the text
Old 12-23-2010 | 10:13 PM
66coronet440's Avatar
i did the drums/shoes on my coronet and it was doing sticking too, the main problem should be the lever return spring or the cable itself, could also be the adjusting star wheel. do you also hear/feel it grinding as you drive or is it silent?
____________________________
1966 Coronet 440 318 poly
Old 12-24-2010 | 04:22 PM
62Furious's Avatar
440 RR has it all there, if it is sticking you may have gotten grease or oil on the pads and that has a tendency to stick or bind
Old 12-24-2010 | 10:00 PM
condor74's Avatar
The long shoe always goes towards the rear. The short shoe always goes towards the front.
Old 01-03-2011 | 11:52 AM
badsport's Avatar
45 years of Mopars
Originally Posted by Ted Dugger
Hi All,
Brake shoes are like mullets, long in the back and short in the front.
Old 01-03-2011 | 10:41 PM
Ha ha ha , Business at the front, party in the back.
Old 01-05-2011 | 03:18 PM
Mistermopar's Avatar
LOL... not quite sure where you were going with this comment, but I had my own visual!!!!
Randy
72demon440
09-13-2013 04:14 PM
breckjar
09-28-2011 09:36 PM
RROriginals
06-13-2010 12:52 AM
panda!
05-08-2009 05:20 PM
needmorecarz
Cuda Specific Discussion
04-05-2007 04:44 AM
Quick Reply: front drum brakes help
