Initial start up
Old May 26, 2014 | 09:46 PM
70newport's Avatar
Initial start up
Hey all,
So I have finally finished putting my 383 back together with the new cam, heads/valves/springs, headers, oil pan and pickup and timing set.
Now I have filled up with xp4 oil with lots of zinc, I have coolant with no thermostat and I am at around 30* before tdc on compression stroke. Are there any suggestions you can make for startup other than keeping at 2000 rpm for 30 minutes?
If I should hear anything weird or perish the thought see oil leaking or something will shutting it down more than likely cause cam failure? Any tips or thoughts would be greatly appreciated! Thanks.
Gary
Old May 27, 2014 | 07:11 AM
Prime the engine before starting......
No... If you have to shut it down, Do so, it Should not hurt anything....
jbda
Apr 1, 2013 10:22 AM
fastdakota84
Jun 25, 2010 01:06 PM
dodgeaspenrookie
Jul 18, 2008 07:28 PM
skinner1980
Jun 4, 2008 07:36 PM
