New member valve issues
Old Feb 3, 2011 | 08:04 PM
Foedoe's Avatar
So a few months back i bought the 67 coronet 4 door for 500 bucks! Wasnt a mopar guy but its hard not to be when you actually have one, anyways put in the edelbrock four bbl intake and carb did some exhaust work during wich i broke a stud off in the drivers head so i had to pull it,
Got everything back on, started up ran perfect, a week ago on the freeway this chirp started under the hood, replaced water pump abd belts, no luck so i took of belts and cranked it to make sure it wasnt a pulley, no luck
Yesterday Found the most likely source of the noise a rocker shaft bolt shim is rubbing on the rocker! It moves a little side to side and the noise is on and off
I torqued the head bolts to 65 lbs and retourqued them after about 200 miles
Lowest setting on my wrench is 25 and even at that i busted a rocker shaf bolt in the head, came out in one piece though
I ordered a rebuilt rocker assy but not sure why the new one wont do the same thing
Any thoughts
Thanks
Old Feb 4, 2011 | 03:05 AM
1966sportfury's Avatar
A.K.A Bob Dodge
[quote=Foedoe;6293 I ordered a rebuilt rocker assy but not sure why the new one wont do the same thing
Any thoughts
Thanks[/quote]
wont do what?
Old Feb 4, 2011 | 06:29 AM
Foedoe's Avatar
Wont rub on the bolt shim and squeak
When i looked at it you could see where it rubs and heated up on the shim
Old Feb 8, 2011 | 06:06 PM
Foedoe's Avatar
Problem solved!
Installed new rocker shaft and rockers(same pushrods and bolt shims) still not sure what it was exactly but its quiet now
Old Feb 8, 2011 | 06:20 PM
condor74's Avatar
what size motor do you have?
Old Feb 8, 2011 | 08:37 PM
Foedoe's Avatar
318 5.2l
76NY440_nTX
Apr 24, 2016 11:45 AM
74Runneer
Oct 17, 2015 10:32 AM
mopar4life
Jun 17, 2012 04:08 AM
Manoharvalves
Sep 15, 2011 10:53 PM
Sovereign
Sep 8, 2010 11:48 AM
