No Brake Lights
Fuses, or the bulbs are corroded into the socket. I had the same problem on my truck. It magically happened after I brought home two big blocks and transmissions
Those would be where I would look.
j
j
Those are the two things that popped into my head when I first read this..
Also, the bulbs may be broken. Start by checking the bulbs, and tracking it down.
-nick
Guest
Posts: n/a
as mentioned, you have to trace the power from the brake switch. since the power is getting to the back you seem to have an open wire between the brake switch and the turn signal switch. check those connectors with a test light to see if the power for the brakes goes in and out of the turn signal switch. check for corrosion in the turn signal switch plug. i think 69 had the 4 way flasher switch on the dash? if so, check that connection too.
Things get a little goofy on these cars. Since the brake and turn share the same lamps, the turn flashes when the brakes are off, but must interrupt the brakes when they are on. Richinnys sharp, listen to him
thanks for the help have been busy with work, will check tomorrow everything tomorrow, i do have another question though, if i replaced the blinker switch, does it matter what wire i hook up, the instructions did not say.
AliceSML79
Aug 22, 2014 03:28 AM
Nate Ryan
Aug 21, 2013 02:15 PM
1966charger
Apr 22, 2012 08:27 PM
Tommyandamanda21
Jul 13, 2011 05:46 PM
