No Brake Lights
Old May 23, 2009 | 06:39 AM
roadrun383's Avatar
Junior Member
No Brake Lights
They were working last time i drove the car, The blinkers and tail lights work, the brake switch is working, does any one have any ideas??
Old May 23, 2009 | 10:26 AM
chlngr1970's Avatar
Fuses, or the bulbs are corroded into the socket. I had the same problem on my truck. It magically happened after I brought home two big blocks and transmissions
Those would be where I would look.
j
Old May 23, 2009 | 10:56 AM
blue 68 gts's Avatar
j
Those are the two things that popped into my head when I first read this..
Also, the bulbs may be broken. Start by checking the bulbs, and tracking it down.
-nick
Old May 23, 2009 | 05:17 PM
roadrun383's Avatar
Junior Member
richinny what do you mean try changing the position of the 4 way flasher, do you mean plug the connector in a different way
Old May 24, 2009 | 09:44 PM
roadrun383's Avatar
Junior Member
its a 69, still no luck with it
Old May 24, 2009 | 10:57 PM
scotts74birds's Avatar
http://www.mymopar.com/downloads/1969/69BelvedereGTXSatelliteRoadRunnerA.JPG
Old May 24, 2009 | 10:59 PM
K, here's a starting poiint. Where does the power stop. With this you will be ok, gert in touch if there is still a problem. Good luck buddy
Old May 25, 2009 | 12:06 AM
no grounding wire or the signal from teh brake switch is not making it all the way to the back.
Old May 26, 2009 | 08:09 PM
Things get a little goofy on these cars. Since the brake and turn share the same lamps, the turn flashes when the brakes are off, but must interrupt the brakes when they are on. Richinnys sharp, listen to him
Old May 26, 2009 | 08:52 PM
roadrun383's Avatar
Junior Member
thanks for the help have been busy with work, will check tomorrow everything tomorrow, i do have another question though, if i replaced the blinker switch, does it matter what wire i hook up, the instructions did not say.
Old May 26, 2009 | 10:23 PM
Sorry, I'm into the sauce now. No more advice tonight! I'm laid off, try you tomorrow, after noon. hic..... hic....I love you man!
Old May 26, 2009 | 10:52 PM
Checked the blinker fluid yet?.............hic........
Old May 28, 2009 | 05:15 PM
roadrun383's Avatar
Junior Member
alright thanks ill check and see if i hooked the blinker switch up wrong.
Old Jun 1, 2009 | 07:11 PM
roadrun383's Avatar
Junior Member
got them fixed thanks for all of your input
Old Jun 1, 2009 | 07:20 PM
So, what was it? This is how we all learn.
AliceSML79
Aug 22, 2014 03:28 AM
1966charger
Apr 22, 2012 08:27 PM
Tommyandamanda21
Jul 13, 2011 05:46 PM
sgp7679
May 25, 2009 06:46 AM
