starting the old beast
Old 02-28-2009 | 08:54 PM
63sportfury's Avatar
well if you read my intro you will know the whole situation with getting this thing started.
the fluids were drained before it sat so im thinking new fluids,new spark plugs and also spraying wd 40 into the cylinders and turning it over by hand before starting then put a new battery in it, unhook the fuel pump (gas line leaks) just add gas to the carb and try to get it cranked up.
anything else i need to do?
Old 03-01-2009 | 07:08 AM
Originally Posted by 66sportfury
clean the carb, maybe drain the tank/lines. and prime the oil pump. should be good to go.
how you go about priming the oil pump? is it completely nessesary?
Old 03-01-2009 | 07:12 AM
instead of WD40 I would use Marvel Mystery oil
Old 03-01-2009 | 07:31 AM
into the cylinder? or just use that type of oil to fill it up?
Old 03-01-2009 | 08:31 AM
to prime the oil pump, the intake manifold needs to be taken off
Old 03-01-2009 | 08:36 AM
does the oil pump have to be primed
Old 03-01-2009 | 09:14 AM
it would probably be best for the engine
it sat for so long, all the oil probably drained down to the oil pan
did you change the oil?
Old 03-01-2009 | 09:15 AM
Use Marvel in the cylinders. Pull the plugs and squirt in a few drops. THat will help the rings seal up better that WD40.
Old 03-01-2009 | 09:16 AM
all the fluids were drained be for it sat when he parked it he drained everything
Old 03-01-2009 | 09:24 AM
if it sat for so many years, valves probably rusted together
same thing happened with my car
Old 03-01-2009 | 09:28 AM
so is it still possible it will run?
Old 03-01-2009 | 09:29 AM
yes
you have to carefully bare the engine over by hand first
while doing it, if you feel resistance, back off, they try again easier
Old 03-01-2009 | 09:48 AM
heres what i should do in order, correct me if i am wrong
put new fluids in
put a few drops of oil into the cylinders
turn over by hand making sure nothing is binding
new plugs
disconnect the fuel pump
put a battery in it
add fuel into the carb
attempt to start it
Old 03-01-2009 | 10:42 AM
ya, that seems good
when baring it over by hand, if you take out the spark plugs, it'll be easier for you
Old 03-01-2009 | 10:44 AM
ok
Old 03-01-2009 | 10:48 AM
what kind of oil do you guys reccommend for a car like this?
Old 03-01-2009 | 10:59 AM
you should read this: https://moparforums.com/forums/f62/o...-engines-2333/
Old 03-01-2009 | 11:22 AM
so i need oil with zinc additive? anything else special? what weight etc... should i get
Old 03-01-2009 | 01:05 PM
i use rotella T its a 15-40
i also use a zinc additive
Old 03-01-2009 | 02:03 PM
alright im gonna try it all next weekend. how do i turn it over by hand i dont think i can get a socket down there or can i?
Old 03-01-2009 | 02:07 PM
you put a breaker bar on the bolt that holds the crank in
Old 03-01-2009 | 02:16 PM
do you happen to know what size the bolt is?
Old 03-01-2009 | 02:18 PM
  #24
hmmm, not exactly, but it is a BIG bolt
around an inch or more maybe
Old 03-01-2009 | 02:32 PM
  #25
i hope i can get a breaker bar down there im not sure if its possible with out removing the radiator. counter clockwise or clockwise?and how many times should i turn it over
Old 03-01-2009 | 02:38 PM
  #26
you should be able to do it
you go clockwise
turn it over a few times, enough so the pistons move freely
Old 03-01-2009 | 02:39 PM
  #27
should itbe hard to turn or easy or in the middle?
Old 03-01-2009 | 02:43 PM
  #28
if the spark plugs are in, it'll be hard
remove them, and it'll be in the middle (you still are moving all the metal, so it wont be easy)
Old 03-01-2009 | 02:45 PM
  #29
should i add the oil before or after i turn it
Old 03-01-2009 | 02:47 PM
  #30
before
Quick Reply: starting the old beast
