starting the old beast
Old Feb 28, 2009 | 07:54 PM
63sportfury's Avatar
well if you read my intro you will know the whole situation with getting this thing started.
the fluids were drained before it sat so im thinking new fluids,new spark plugs and also spraying wd 40 into the cylinders and turning it over by hand before starting then put a new battery in it, unhook the fuel pump (gas line leaks) just add gas to the carb and try to get it cranked up.
anything else i need to do?
Old Mar 1, 2009 | 06:08 AM
Originally Posted by 66sportfury
clean the carb, maybe drain the tank/lines. and prime the oil pump. should be good to go.
how you go about priming the oil pump? is it completely nessesary?
Old Mar 1, 2009 | 06:12 AM
instead of WD40 I would use Marvel Mystery oil
Old Mar 1, 2009 | 06:31 AM
into the cylinder? or just use that type of oil to fill it up?
Old Mar 1, 2009 | 07:31 AM
to prime the oil pump, the intake manifold needs to be taken off
Old Mar 1, 2009 | 07:36 AM
does the oil pump have to be primed
Old Mar 1, 2009 | 08:14 AM
it would probably be best for the engine
it sat for so long, all the oil probably drained down to the oil pan
did you change the oil?
Old Mar 1, 2009 | 08:15 AM
Use Marvel in the cylinders. Pull the plugs and squirt in a few drops. THat will help the rings seal up better that WD40.
Old Mar 1, 2009 | 08:16 AM
all the fluids were drained be for it sat when he parked it he drained everything
Old Mar 1, 2009 | 08:24 AM
if it sat for so many years, valves probably rusted together
same thing happened with my car
Old Mar 1, 2009 | 08:28 AM
so is it still possible it will run?
Old Mar 1, 2009 | 08:29 AM
yes
you have to carefully bare the engine over by hand first
while doing it, if you feel resistance, back off, they try again easier
Old Mar 1, 2009 | 08:48 AM
heres what i should do in order, correct me if i am wrong
put new fluids in
put a few drops of oil into the cylinders
turn over by hand making sure nothing is binding
new plugs
disconnect the fuel pump
put a battery in it
add fuel into the carb
attempt to start it
Old Mar 1, 2009 | 09:42 AM
ya, that seems good
when baring it over by hand, if you take out the spark plugs, it'll be easier for you
Old Mar 1, 2009 | 09:44 AM
ok
Old Mar 1, 2009 | 09:48 AM
what kind of oil do you guys reccommend for a car like this?
Old Mar 1, 2009 | 09:59 AM
you should read this: https://moparforums.com/forums/f62/o...-engines-2333/
Old Mar 1, 2009 | 10:22 AM
so i need oil with zinc additive? anything else special? what weight etc... should i get
Old Mar 1, 2009 | 12:05 PM
i use rotella T its a 15-40
i also use a zinc additive
Old Mar 1, 2009 | 01:03 PM
alright im gonna try it all next weekend. how do i turn it over by hand i dont think i can get a socket down there or can i?
Old Mar 1, 2009 | 01:07 PM
you put a breaker bar on the bolt that holds the crank in
Old Mar 1, 2009 | 01:16 PM
do you happen to know what size the bolt is?
Old Mar 1, 2009 | 01:18 PM
  #24
hmmm, not exactly, but it is a BIG bolt
around an inch or more maybe
Old Mar 1, 2009 | 01:32 PM
  #25
i hope i can get a breaker bar down there im not sure if its possible with out removing the radiator. counter clockwise or clockwise?and how many times should i turn it over
Old Mar 1, 2009 | 01:38 PM
  #26
you should be able to do it
you go clockwise
turn it over a few times, enough so the pistons move freely
Old Mar 1, 2009 | 01:39 PM
  #27
should itbe hard to turn or easy or in the middle?
Old Mar 1, 2009 | 01:43 PM
  #28
if the spark plugs are in, it'll be hard
remove them, and it'll be in the middle (you still are moving all the metal, so it wont be easy)
Old Mar 1, 2009 | 01:45 PM
  #29
should i add the oil before or after i turn it
Old Mar 1, 2009 | 01:47 PM
  #30
before
