Water Pump issues
Old Jan 7, 2019 | 09:09 PM
Nathan Jorgenson's Avatar
Water Pump issues
My water pump was leaking on my 1967 318 engine, when I went to take it off the pump blades were smashed and 3 are gone. The pump blades also carved there way into the pump about an 1/8 of an inch. The pump is replaceable but should I go looking for the fan blades?
This is the water pump
Old Jan 8, 2019 | 06:16 AM
Archer's Avatar
Nathan -
Sounds like the bushing that centers/holds the shaft in place is gone.
I'd just replace the whole thing with a new high flow unit, especially since the housing was damaged.
Old Jan 8, 2019 | 02:40 PM
I was going to get a new water pump but should I go through the mess of trying to get the fan blades. And if I should how would go out doing that?
Old Jan 8, 2019 | 03:35 PM
Archer's Avatar
Nathan -
I wouldn't bother.
Old Jan 8, 2019 | 04:15 PM
New pump.
Old Jan 8, 2019 | 07:19 PM
I Agree.... Don't be to concerned about the blades.... New pump for sure.... Also Look at the Timing Cover and make sure it is not damaged.
Old Jan 11, 2019 | 06:54 AM
Timing cover is damaged, not as bad as the waterpump though. Its just a 1mm circle in the timing cover.
Old Jan 11, 2019 | 03:10 PM
If it's not deap go ahead and use it.
Old Jan 11, 2019 | 08:46 PM
LA water pumps and a used housing are a dime a dozen. A rebuilt water pump comes with a new impeller
gunnerman
Apr 30, 2021 06:05 PM
woodyfryar@att.net
Apr 19, 2016 06:52 PM
TypeO
Mar 20, 2015 08:39 AM
motasupra
Sep 29, 2014 11:59 AM
mikeynags
Aug 9, 2009 03:52 PM
