What could cause Carter AFB 9605s to run lean under load
Old May 14, 2018 | 01:20 PM
Al440's Avatar
I'm stuck, I've rebuilt the carb, got the calibration kit tried different combinations of rods jets springs and nothing with fix this problem. It's a 600cfm on a 440 with edelbrock intake. Is it too small of a carb for the engine? Bad fuel pump? What else could cause this? It idles perfect, but when I take it on the road it seems like it doesn't have the power it should, the plugs are clear white after a drive but tan after sitting at idle
Old May 14, 2018 | 02:42 PM
Carbs too small
Old May 15, 2018 | 07:50 PM
carb is too small for a 440, also I suspect it was jetted for a GM application when new
maca
Mar 23, 2014 08:55 AM
Bergmann54
Nov 10, 2013 03:46 PM
ottosen@chorus.net
Aug 4, 2011 05:24 AM
Moss
Jul 5, 2011 05:26 PM
68camperspecial
Apr 14, 2009 05:28 AM
