What project are you working on?
Old Oct 9, 2015 | 12:57 PM
  #241
Originally Posted by Magoo
-- In my 440/500 (68 Dart) - see Albums. -- I had a 850 Holley - a Mopar .509" Hydraulic Cam and used 93 octane from the pump. - With 3.73 (Non Mopar) gears and driven daily on the street, it ran mid 11s at 123 MPH (fast for mid 11s - a good indicator of better E.T.s) -- I believe, with a 1050 carb and around 3.91 gears, it was capable of real low 11s, possibly a high 10. - I set the shift lite at 5,000 and probably shifted around 5,200 - 5,300 RPM - Old man you know. -- It weighed 3,3XX lbs. -- I didn't build it, but I believe that it was a 10:1 motor.
I've got 12.5 -1
Old Oct 9, 2015 | 01:15 PM
  #242
Magoo's Avatar
Thumbs up More Octane
I've got 12.5 -1
93 pump gas is out. -- Sounds like a 10s car or better depending on weight, convertor, carb, cam, gears etc., etc. -- Good Luck.
Old Oct 9, 2015 | 01:28 PM
  #243
The thing about E85 is it can add +30 hp because the fuel/air charge is so cold.
Old Mar 27, 2016 | 09:31 AM
  #244
Vengeance 22's Avatar
I fixa all.
Old Mar 27, 2016 | 07:28 PM
  #245
BBQ Today....
Old Apr 1, 2016 | 09:04 AM
  #246
premierresto's Avatar
1969 Dodge charger restomod
Old Apr 1, 2016 | 09:58 AM
  #247
1963 Chevy C-20 Pick up...Electrical...
1977 Dodge D150 Pick Up.... C.B.Radio Problem...
Old Apr 7, 2016 | 06:02 AM
  #248
Working on Brand-X This Weekend....... This use to Be Mickey Thompsons Mechanics old Drag Race / Dirt Track Car...
Attached Thumbnails What project are you working on?-bobs-pics122009-009.jpg
Old Apr 16, 2016 | 03:31 PM
  #249
Good Afternoon Y'all..... Happy Saturday fun day.....
Also a great Air Show.... http://marchfieldairfest.marchfss.com/
I'm working on a Brand-X 1963 pick up.... Wiring... And man is it hot in this cab with the sun out..... Yep no shade.....
Stay Tuned...
Old Apr 16, 2016 | 03:33 PM
  #250
Any Up-Dates ???????
Old Apr 16, 2016 | 05:35 PM
  #251
Lets here them!
Old Apr 16, 2016 | 07:57 PM
  #252
Took down a tree in the backyard today.
Old Apr 17, 2016 | 11:28 AM
  #253
Brand-X wiring gremlins....
Old May 4, 2016 | 08:05 PM
  #254
Kvamme33's Avatar
New leaf springs 79 powerwagon
Hello I have a 79 powerwagon that has a gm 10 bolt front differential on it. Not sure what kind of leaf springs to order? I just had the 318 in this truck fully rebuilt previous owner took tranny, t-case,and front differential off a 87 gmc I think. It has Warner locking hubs on it very nice truck just don't know much about this and buy no means. Thanks for your help and time.
Old May 4, 2016 | 08:44 PM
  #255
Kvamme33's Avatar
Hello there I have a 79 power wagon w200 that has a gm10 bolt front defferental on it. Previous owner put tranny, t-case, and front defferental to swap from full time4x4 to part time from a 87gmc (I think)! My question is what front leaf springs do I order or does it really matter? I think the truck came with a Dana 44 but not sure thanks for any help or input on this. Iam not a mechanic buy any means
Old May 5, 2016 | 08:38 AM
  #256
If you don't have the old springs to match..... Measure the Eye to Eye where the spring goes and Hit up you local spring repair shop.... They can get you a spring that will fit your need... The other question will be "Ride Height" they will tell you what is needed for that info.... Keep us posted...
Old May 5, 2016 | 05:41 PM
  #257
The Ford engine train left our shop on the weekend (Ford son's engines on the trailer to his new house) our V10 Magnum back to us. One of the snowmobiles to Mom's and her rider back into our roomy shop. Welding up the cracked mowing deck last night so Ford son can have a rider for his now bigger property.
Looking forward to racing Dodge son's Demon, still have to build a fuel line cover through bellhousing area. Really looking forward to building the new/next engine with the high end parts I've collected over some time, shooting for 500hp 318 on this one.
Old May 5, 2016 | 06:31 PM
  #258
I love those 500H.P. Teen's.... Little tricky getting it there.... But once you hit it.... Those things run like a stripped azzed ape !!!!!!
Old May 6, 2016 | 02:16 PM
  #259
I'm tubing the block and starting solid flat going solid roller next year is the plan. Showed the son a video of old Modified Production cars and he's all small cubes, big rpm, clutch for him now. I like his old soul.
Still wondering if to use hard water pipe or soft refrigerant copper, what do you guys think. I was told the water pipe won't crack.
Old May 6, 2016 | 04:59 PM
  #260
I think I would stick what has work for many moons.... Cooper Style...
P4120603 For the large roller and race only application...
Just my 2 cents...
Old Dec 29, 2016 | 03:08 AM
  #261
t65fury3's Avatar
Originally Posted by kowalski
I am currently working on a 66 Fury II. Its all original with a poly 318, a/c, and 10" 4 wheel drum brakes with no power assist. My plans for this car are a built 383 with 911 heads. And since its gonna be faster, Ill need to replace the puny drum brakes with some beefy discs up front. It was origanally silver with blue interrior but some one had started pretting it to repaint and stripped all the paint and never primed it. So it has surface rust all over the bodie, nothing serious. I figure itll make one hell of a sleeper. LOL
how is the poly running
Old Dec 31, 2016 | 11:06 PM
  #262
mudman's Avatar
Just joined the site today after buying a nice clean fairly original 69 Dart Custom, nothing fancy but fairly well built 318. Looking forward to learning Mopar again, 1st real car at 18 was a 69 Charger R/T SE 440 4spd w a Dana 60, miss those days of fun and a few tickets.
Mudman.
Old Jan 1, 2017 | 04:31 AM
  #263
t65fury3's Avatar
Mudman.
welcome sir I'm fairly new here to and learning about the mopar stuff these guys have a great help section and have really nice wanna help people so good luck.i also have a 318 its ok blowing smoke but its been sitting so ill run it for now good luck to you
Old Jan 1, 2017 | 11:35 AM
  #264
Welcome to the site..... Have fun....
Old Jan 1, 2017 | 11:58 AM
  #265
Thumbs up
Welcome Mr Mud
Old Jan 1, 2017 | 02:02 PM
  #266
mudman's Avatar
Thanks for the great welcome, been out working on the Dart all day, quite original car, quite happy with it, want to read all I can and do a proper build on the car, also got a 360 as part of the deal so maybe down the road but 318 is a nice built so looking at changing up to 15" rims instead of the factory 14". Bolt circle seems really small so may be hard to find rims, will see what the site says.
Mudman.
Old Jan 1, 2017 | 02:43 PM
  #267
Your Dart has the small 4.25 on 5 bolt pattern, if you swapped out the front brakes for 73 and latter disks and then got the axles and drums from the same car that would change your bolt pattern to the 5 on 4.5.
This would open up your wheel selection.
Old Jan 1, 2017 | 02:45 PM
  #268
I Agree.... And a lot better stopping.....
Old Jan 1, 2017 | 10:41 PM
  #269
mudman's Avatar
So 73 and later A body then I imagine you mean, do I heed spindles too, appreciate the help, wow 4.25 is small. So 5 on 4.50 is next step up.
Mudman.
Old Jan 2, 2017 | 04:22 AM
  #270
Yes spindle also, master cylinder etc..
