400 -> 440 73' D100 swap?
Old Aug 26, 2009 | 01:53 PM
Yes it is a simple swap. The 400 and 440 motors are basically the same block on the outside.
Old Aug 27, 2009 | 12:47 AM
If that is the case, I know that swapping in a 440would be easier and cheaper, but I'd rebuild that 400 as they are a great BB motor for what you want to do.
Old Aug 27, 2009 | 11:34 AM
just make sure that the launches are dry and that you have a good set of tires. maybe throw a sure grip in the rear for added get-up-and-go.
Old Aug 28, 2009 | 07:29 PM
crmzendrgone's Avatar
Hell I would jump on that. Thats me though, spend the money rebuilding the 440.
Old Aug 28, 2009 | 10:59 PM
scotts74birds's Avatar
I dont know where you are finding these, but Craigslist rules around here! Folks have these 70's motorhomes that arent worth ****, but they have 440's.hd trans's, and they are giving them away for 5-700 bucks
Old Aug 28, 2009 | 11:23 PM
Thats why we are here!
Old Aug 29, 2009 | 12:00 AM
chlngr1970's Avatar
Where are you located? I think I may have seen that same CL ad for that Winne 440
Anyway...if you are thinking of rebuilding, you could always get a stroker kit from 440source.com. That is where i am headed with my Duster
j
Old Aug 29, 2009 | 04:48 AM
How about putting a 440 crank in the 400 block?? Doesn't take much machine work and that give you 451". I have two such engines and the power my 3,000 lb Barracuda to low 10.00's at 133mph. Plenty of torque and lots of power... Just another way of getting inches from what you have....
Old Aug 29, 2009 | 09:15 AM
chlngr1970's Avatar
Well, if it is running well enough, why not pick up a core 400? You could then use time as your weapon and gather the parts you need. That is my plan ( except life seems to have other ideas...interested in a 68 Dart? ) Right now, I am waiting on October to get my next installment on my projects. The other half seems to be having issues tho, and I may need to sell the Dart. Whatever. I am hoping to find a D200 that I can replace my D100 with. Then I would have a towing rig...most likely stock with a big block. I also have a few big blocks laying around...so
j
Old Aug 30, 2009 | 05:51 PM
chlngr1970's Avatar
Unfortunately, I don't know. Is there room to extend the brake booster up, like with the A-Bodys? Similar to this?
j
Old Aug 30, 2009 | 05:58 PM
chlngr1970's Avatar
Besides, the 440 isn't THAT much taller than the 400. I guess that with the 440 vs. the 400, might be the same principle as the A Body. Since you can use B Body headers with the 400 in an A, but not the 440...
j
Old Aug 30, 2009 | 08:46 PM
  #25
Originally Posted by Iskone
I may just do that, it just all depends on how things line up. See I reeeeeealy want a boat but I also wanna/need build up my motor a bit, can't have both. So I may just buy a small 19ft fiberglass boat off my buddy for a grand and then collect parts for my BB build. That other boat is so small that it wouldn't even phase my truck, I've hauled a couple 1 ton loads w/o all. So that's where I'm at.
You dont need a boat, you only need a FRIEND with a boat! Glad you found and RV with a motor you want.
Old Sep 4, 2009 | 09:03 AM
  #27
A buddy of mine has a 76 he pulled the 383 that was in it out and put a 440 out of an RV into it and he says that the valve cover hits the booster and causes the cover to leak. He has tried different covers and all but it still leaks. But maybe he has another issue still haven't been able to get my hands on his truck.
I was close once, could of had it for myself for $6500 after he put 25K into it. Damn Damn dirty wife, Uh I mean ape. (Maybe the same thing) HAHAHA
Old Sep 4, 2009 | 10:57 AM
  #28
chlngr1970's Avatar
Muhahahjaha I bought the 440 for $100, got a bunch of gaskets and other crap for another $20. I scored!
I'm still not sure what I'll do, build up the 400, the 440, stroker? I'll just play it by ear I guess. I can get the 440 crank offest ground for $75 and then use BBC rods for a 3.9 stroke.
Good score! I got my two 400s and 727s for $400 You should have seen my poor truck...it was AWESOME! I also picked up a 77 Winnebago with a 440/727 for $400 and drove it from Tacoma to Everett Now I just need to fix the Alternator bracket issue and run with it.
You said before this was a driver and you need it. What about finding a good buildable 400 and go from there? Or, can you offset the brake booster to fit the 440?
j
Commando
Apr 3, 2018 01:36 AM
Jvz
Jul 28, 2014 08:36 AM
chlngr1970
Sep 30, 2010 08:54 AM
Iskone
Jul 17, 2009 08:46 PM
