426 Hemi exhaust manifold gasket problem
Old May 16, 2016 | 08:19 AM
J rod's Avatar
Was wondering what type of exhaust manifold gasket anyone could recommend for a 426 Hemi? I also read that instead of a gasket to use high heat gold silicone? Has anyone tried this?
Old May 16, 2016 | 06:48 PM
Welcome J to the site..... Not sure what the problem is with the gaskets your using? But are you just going Iron Head to Iron Manifolds?
If so.. Make certain that the manifolds are Flat.. Some time these are know to warp out of shape and cause the gaskets to blow out.. TTI has them and Also Mancini Racing.. Hope this helps
Keep us posted..... Will stay tuned.....
Old May 16, 2016 | 09:10 PM
J rod's Avatar
Bob,
Thanks! blew a gasket last summer and replaced it with a new one (Mr Gasket Co.)
Took the car out this spring and it was leaking again on the same side but in a different spot. I didn't notice any warps. Maybe cause it should have been re torqued?
Old May 17, 2016 | 06:23 AM
J... Some guys like to install the gaskets with the exhaust still hooked to the manifold.... My suggestion is install the exhaust manifold and then install the exhaust at the flange. Then after a few heat cycles come back and just give them a snug... Hope this helps..... Keep us posted.. Got to love a Hemi Car!!!
J rod
May 16, 2016 06:53 PM
auerdoan
Jun 11, 2011 05:55 PM
timmie124
May 24, 2011 08:08 AM
68 Sat
Jan 10, 2010 03:49 PM
M1 Manifold
May 21, 2009 02:23 PM
